Verifying outbound, non-DHCP traffic goes through VPN
Denna
1) When OpenVPN is setup on Asuswrt-Rmerlin, how do you verify all outbound, non-DHCP traffic is going through the VPN ?
2) How does a killswitch enforce this ?
Not sure what you are referring to with "non-DHCP traffic", but the setting "Redirect Internet Traffic" can be configured with different option to fulfill the traffic routing needs.
You can check the routing by going to a internet site which shows your IP - e.g. google.com query... :cool:
I assume the VPN setup option "Block routed clients if tunnel goes down" (see VPN / OpenVPN Clients) is the kill-switch you are looking for... :rolleyes:
Can you turn on policy restrictions and set the source IP to 0.0.0.0/0 and the destination to 0.0.0.0 and the type to VPN? That should default your entire network to go through the VPN. If you need to create a few exceptions, then you can add those ranges with a type=WAN.
R Getting rc_service log non-stop Asuswrt-Merlin 16
