S
SyscomDT
Guest
Hello,
I have configured a few access point at a local coffee shop that seems to be constantly experincing connection issues. We are having problems with clients connections bouncing from one AP to the next, without successful connections, or simply unable to connect to any of the AP's. There are several other AP's in the area on varying channels.
Below are the Devices currently being utilized in the coffee shop:
1. Motorola 3347 DSL Modem
-AP on Channel 11
-Acting as Gateway, Router, NAT
2. Linksys WRT54GL using latest DD-WRT
-AP on Channel 1
-Acting as DHCP Server, Switch
3. Netgear WG302 with latest Firmware
-AP on Channel 6
*All Wireless AP's have Open unencrypted Networks with different SSID's.
*Device 3 is connected to device 2 via Cat5e
*Device 2 is connected to device 1 via Cat5e
*Atleast 150 different devices connect to these AP's per day
Device 1 and 2 are about 1 foot apart (should I change this?)
Device 3 is 50 feet away.
I've had to reset the devices many times to get things working again. It seems that the DHCP Server is running out of IP's, but I have it set to only a 90 minute lease time.
Question 1: Any immediate suggestions?
Question 2: Can I use a much lower DHCP time without connection issues on the client end?
Question 3: Is there a problem with having two AP's close together on seperated channels?
Question 4: If you were to set this up optimally, would you replace a device with one that can handle more connections(All access is wireless)?
Thanks in advance for any and all help!
Regards,
-Scott
-AP on Channel 11
-AP on Channel 1
-AP on Channel 6
Regards,
-Scott
