vi edit /jffs/scripts hang
threemonks
Recently I am unable to edit script /jffs/scripts using vi. I can launch the editor with the script, and make changes, but when I try to save and quit :)wq) or quite without save :)q), it will just hang.
Any idea what might be causing this?
Apart from the obvious.... you are not trying to vi '/jffs/scripts' right?
I suggest you try the 'easier' nano editor.
What router? What firmware?
I was editing script /jffs/scripts/firewall-rule.
It is RT-AC3200, asuswrt-Merlin firmware version 384.13_2
My RT-AC3200 is now at the bottom of the closet since I no longer support that model, so I can't test it.
I would second Martineau's advice and switching to nano as a workaround.
When I tried nano, I got this error:
Error opening terminal: screen.
Which SSH client are you using?
Try setting terminal type to 'xterm'
I am connecting to the router from another linux box under screen.
I tried to ssh via putty directly, so the TERM is xterm, and then tried nano, it now seems to hang with a status text at bottom says "Reading File".
I also noticed that whenever I try to tab complete command on shell, the ssh session will hang as well.
Sounds like a terminal problem to me, not a firmware issue. Try with a more standard SSH session rather than through screen.
It seems like some kind of memory issue. I was experiencing hang even with pure putty login. I finally got it to work after a reboot.
