VLAN or Isolated LAN for IP Cameras using ASUS RT-AC68U?
I don't know the answer to that question, but reboots are often helpful. I have the script being called from the `nat-start` script. The merlin wiki has good documentation on getting started with scripts, here.
Edit: Are you sure that the device on your main network that you want to be able to access the IOT devices (and vice versa) is connecting to the router via the MAC address you are whitelisting? Some devices have more than one MAC (i.e. wifi, Ethernet, bluetooth...)
Doubled checked the MAC, and it's correct. Wired connection.
Added the script to nat-start, and it works as expected after reboot.
Still unreachable though :(
