VPN client
agadave
Hello,
on the asus RT-66U with 380.70 (mode router),
it is possible to use the VPN client on some PCs and not other PCs ?
ex:
PC1/ETH1 use VPN
PC2:ETH2 don't use VPN
wifi: don't use VPN
Thank you
No it's not possible to select different routes based on the physical connection. You can use the VPN's policy routing but that is based on IP address not the physical connection.
Hello,
ex:
PC1/ETH1 use VPN
wifi: don't use VPN
Yes.
e.g. 2.4 Guest WiFi 1 SSID Wl0.2 and Switch Port 4 can both be re-assigned to a new bridge interface say 'br1' on a new subnet (aka VLAN) and routed via a VPN.
Actually RPDB rules allow you to also specify the physical interface
e.g
ip   rule   add   prio   1000   from   1.2.3.4/28    iif    br1    lookup    dmz
Yes.
e.g
I was talking about what was possible using the router's normal web interface, not what was possible with user-written scripts.
