Hi, had done all those things perfectly. Everything was working fine until a few days ago.
As I suspected. On contacting my VPN provider they mentioned that they did some migrations that wouldn't allow DNS to leak upstream. On my request they set my VPN to OpenDNS in their settings.
Hi
I am not understanding one thing. Why would do you need to use a VPN?
The majority of people do it for downloading movies and geometric locations and to have an anonymous IP so that they can surf a little more securely.
When you have a VPN the IP address and DNS are suppose to be the Same. This normal because in order to setup a secure line from the server to the client.
this way anytime your browser will call for a address the DNS from the VPN will work and not opendns. If you download movies from pirate bay or other torrents, they will know right away who you are, because opendns are public. So why would you want to have open dns for all devices?
Wouldn't you want to control which devices have VPN and which don't? and control their DNS as well?
You can easily do it via selective routing use Policy Rules in VPN client also enable if tunnel goes down drop connections and put the following;
192.168.1.0/24 source IP 0.0.0.0 destination IP and lface VPN this will force all traffic to the VPN
then you can put all the devices that you don't want using the VPN
for example your kids iPad 192.168.1.75 source IP 0.0.0.0 destination and lface WAN this will use your local internet service provider
You can easily Assign static IP for each device as I used in the example and have devices that you don't want using the VPN.
then you can go to DNSfiltering and point openDNS to the IP address's that you didn't want to be on the VPN.
Now any device that is not on the WAN rule and its traffic will use the VPN and its DNS which is secure.
and all the devices that are on local internet ISP will be surfing with openDNS for kids or whatever you choose because when you use dnsfiltering you can put up to 3 dns so your kids can have opnedns and you can have opendns for adults or google etc.
You can even do it where you add specific address's to use VPN and automatically every other device will go through your Local ISP and you can setup dnsfiltering for the devices that you want to use openddns
Its all explained here
http://www.snbforums.com/threads/ho...y-step-how-to-guide-ver-380-58-updated.30851/
Think about what you did, You really don't need a VPN if you are going about it the way you are.
good luck
