I'm using the latest merlin firmware xxx.35 on an Asus AC66U Router
I setup a PPTP VPN to connect with a Win 8.1 client. First connection everything works correctly and the client can be seen in the VPN status list.
If I then disconnect and try to reconnect I get an 807 error. The VPN status list shows no clients
I have 10 IP addresses available for the VPN server.
If I then access the router and click "Apply" on the VPN settings page...which I assume causes the VPN server to restart and then try to connect again it will work.
Is this a bug in the VPN server or my own doing?
Thanks again for the great firmware!
