Wan acess Transmission
I tried:
"rpc-whitelist": "*.*.*.*",
"rpc-whitelist-enabled": false,
and
"rpc-whitelist-enabled": true,
but no sucess...strange, from PC and iPad it works...
I'm trying to access Transmission web through WAN and I can't get it to work.
My firewall-start file looks like this (-rwxr-xr-x /jffs/scripts/firewall-start):
#!/bin/sh
iptables -I INPUT -p tcp --destination-port 51413 -j ACCEPT
iptables -I INPUT -p udp --destination-port 51413 -j ACCEPT
ifconfig br0:trans 192.168.1.10 up
sh /jffs/scripts/firewall start skynetloc=/tmp/mnt/sda1/skynet # Skynet Firewall Addition
iptables -I INPUT -p tcp --destination-port 9091 -j ACCEPT
My settings.json looks like this:
"alt-speed-down": 50,
"alt-speed-enabled": false,
"alt-speed-time-begin": 540,
"alt-speed-time-day": 127,
"alt-speed-time-enabled": false,
"alt-speed-time-end": 1020,
"alt-speed-up": 50,
"bind-address-ipv4": "192.168.1.10",
"bind-address-ipv6": "::",
"blocklist-enabled": false,
"blocklist-url": "http://list.iblocklist.com/?list=bt_level1",
"cache-size-mb": 2,
"dht-enabled": true,
"download-dir": "/mnt/sda1/downloads",
"download-queue-enabled": true,
"download-queue-size": 5,
"encryption": 0,
"idle-seeding-limit": 30,
"idle-seeding-limit-enabled": false,
"incomplete-dir": "/mnt/sda1/downloads",
"incomplete-dir-enabled": false,
"lpd-enabled": true,
"message-level": 1,
"peer-congestion-algorithm": "",
"peer-id-ttl-hours": 6,
"peer-limit-global": 50000,
"peer-limit-per-torrent": 3000,
"peer-port": 51413,
"peer-port-random-high": 65535,
"peer-port-random-low": 49152,
"peer-port-random-on-start": false,
"peer-socket-tos": "lowcost",
"pex-enabled": true,
"port-forwarding-enabled": false,
"preallocation": 1,
"prefetch-enabled": false,
"queue-stalled-enabled": true,
"queue-stalled-minutes": 30,
"ratio-limit": 2,
"ratio-limit-enabled": false,
"rename-partial-files": true,
"rpc-authentication-required": true,
"rpc-bind-address": "0.0.0.0",
"rpc-enabled": true,
"rpc-host-whitelist": "",
"rpc-host-whitelist-enabled": false,
"rpc-password": "PASSWORD",
"rpc-port": 9091,
"rpc-url": "/transmission/",
"rpc-username": "USERNAME",
"scrape-paused-torrents-enabled": true,
"script-torrent-added-enabled": false,
"script-torrent-added-filename": "",
"script-torrent-done-enabled": false,
"script-torrent-done-filename": "",
"seed-queue-enabled": false,
"seed-queue-size": 10,
"speed-limit-down": 100,
"speed-limit-down-enabled": false,
"speed-limit-up": 100,
"speed-limit-up-enabled": false,
"start-added-torrents": true,
"trash-original-torrent-files": true,
"umask": 18,
"upload-slots-per-torrent": 14,
"utp-enabled": true,
"watch-dir": "/opt/etc/transmission/watchdir",
"watch-dir-enabled": true
I can see that the router is listening on port 9091:
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State
tcp 0 0 0.0.0.0:9091 0.0.0.0:* LISTEN
I have both Diversion and Skynet installed and the next step after web access to Transmission is to set it up to work behind VPN.
I have no problem using Transmission web inside my LAN on port 9091, but from WAN 9091 is closed, so it looks like a firewall issue?
It's not a firewall issue...
Understand what these config setting really mean in the transmission config file...
"rpc-port": 9091,
You can always review here...
https://github.com/transmission/transmission/wiki/Editing-Configuration-Files
Just keep in mind, any service on the WAN can be problematic...
"rpc-port": 9091,
When I opened port 9091 in the AC86u GUI it worked, didnt need to re-edit settings.json. Now i just need to configure it to work behind VPN.
