Sean Rhodes
I am also have similar issues to what I have seen in some of the posts and have actually had to go back to stock firmware to fix it.
My ISP is Cogeco.ca and I have a Cisco DPC3848VM modem which I setup in Bridge mode. I use my Asus RT-AC3200 which has been working fine for the last couple of years.
Recently however it started dropping connections, occasionally in build 384.8, more so in 384.10 and completely broken in firmware build 384.10_2.
What happens is when the router powers up, it sees the WAN IP assigned by Cogeco for about 1.5 secs and then immediately goes to disconnected and I have no internet access. If I plug in directly to the cable modem, the internet is there.
I performed a complete wipe, re-flashed back to Asus stock fimware and everything works. I let it run for a day and then re-loaded 384.10_2 firmware where it ran for couple of hours and then the WAN IP became disconnected again.
Currently the only way I can get a reliable connection is by reverting back to ASUS stock firmware, which i'mcurrently running at the moment.
I'm attaching my syslog in order that somebody can give me some pointers. I did notice there are a couple of issues, firstly it looks lite the NTP server wasn't running and the system time is a year off. I also see the following "WAN_Connection: ISP's DHCP did not function properly."
I keep trying to upload my syslog but it doesn't seem to work past the selection option
