WAN disconnections
junkone
i have been having WAN disconnections in evening with Start.ca Cable.
here is a link of the logs.
http://pastie.org/8546163
I set the DHCP query frequency = Normal.
When i spoke to them they wanted me to monitor it with a PC and will not troubleshoot with a Router log. can you help me figure out this one?
here is extract of log and it happened twice this evening and 5 times yesterday evening.
@@ Dec 11 20:42:56 WAN Connection: ISP's DHCP did not function properly.
Dec 11 20:42:56 stop_nat_rules: apply the redirect_rules!
Dec 11 19:43:02 dnsmasq[11638]: exiting on receipt of SIGTERM
Dec 11 20:43:02 dnsmasq[28906]: started, version 2.67 cachesize 1500
Dec 11 20:43:02 dnsmasq[28906]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth
Dec 11 20:43:02 dnsmasq[28906]: asynchronous logging enabled, queue limit is 5 messages
Dec 11 20:43:02 dnsmasq-dhcp[28906]: DHCP, IP range 192.168.1.2 -- 192.168.1.254, lease time 1d
Dec 11 20:43:02 dnsmasq-dhcp[28906]: DHCP, sockets bound exclusively to interface br0
Dec 11 20:43:02 dnsmasq[28906]: read /etc/hosts - 5 addresses
Dec 11 20:43:02 dnsmasq[28906]: using nameserver 64.140.114.23#53
Dec 11 20:43:02 dnsmasq[28906]: using nameserver 64.140.114.22#53
Dec 11 20:43:02 dnsmasq[28906]: using nameserver 64.140.114.21#53
Dec 11 20:43:15 dnsmasq-dhcp[28906]: DHCPINFORM(br0) 192.168.1.185 00:1d:72:57:01:39
Dec 11 20:43:15 dnsmasq-dhcp[28906]: DHCPACK(br0) 192.168.1.185 00:1d:72:57:01:39 HP-PC
Dec 11 20:44:06 cstats[322]: Problem loading /mnt/Seagate_Expansion_Drive/TrafficLogs/tomato_cstats_08606e22aa48.gz. Still trying...
Dec 11 20:44:14 dnsmasq-dhcp[28906]: DHCPREQUEST(br0) 192.168.1.249 00:66:4b:ec:d7:4d
Dec 11 20:44:14 dnsmasq-dhcp[28906]: DHCPACK(br0) 192.168.1.249 00:66:4b:ec:d7:4d android-77657ad29d9eac34
Dec 11 20:44:16 rstats[314]: Problem loading /mnt/Seagate_Expansion_Drive/TrafficLogs/tomato_rstats_08606e22aa48.gz. Still trying...
Dec 11 20:44:44 dnsmasq-dhcp[28906]: DHCPREQUEST(br0) 192.168.1.227 00:24:2c:ac:6a:8e
Dec 11 20:44:44 dnsmasq-dhcp[28906]: DHCPACK(br0) 192.168.1.227 00:24:2c:ac:6a:8e
Dec 11 20:44:49 dnsmasq-dhcp[28906]: DHCPINFORM(br0) 192.168.1.227 00:24:2c:ac:6a:8e
Dec 11 20:44:49 dnsmasq-dhcp[28906]: DHCPACK(br0) 192.168.1.227 00:24:2c:ac:6a:8e
Dec 11 20:45:05 dnsmasq-dhcp[28906]: DHCPINFORM(br0) 192.168.1.70 9c:2a:70:47:39:b4
Dec 11 20:45:05 dnsmasq-dhcp[28906]: DHCPACK(br0) 192.168.1.70 9c:2a:70:47:39:b4 CSB070316-W7
Dec 11 20:46:23 dnsmasq-dhcp[28906]: DHCPINFORM(br0) 192.168.1.227 00:24:2c:ac:6a:8e
Dec 11 20:46:23 dnsmasq-dhcp[28906]: DHCPACK(br0) 192.168.1.227 00:24:2c:ac:6a:8e
Dec 11 20:48:00 dnsmasq-dhcp[28906]: DHCPINFORM(br0) 192.168.1.70 9c:2a:70:47:39:b4
Dec 11 20:48:00 dnsmasq-dhcp[28906]: DHCPACK(br0) 192.168.1.70 9c:2a:70:47:39:b4 CSB070316-W7
@@ Dec 11 20:48:36 WAN Connection: WAN was restored.
@@ Dec 11 21:16:07 WAN Connection: ISP's DHCP did not function properly.
Dec 11 21:16:07 stop_nat_rules: apply the redirect_rules!
Dec 11 21:16:13 dnsmasq[29027]: exiting on receipt of SIGTERM
Dec 11 21:16:13 dnsmasq[30138]: started, version 2.67 cachesize 1500
Dec 11 21:16:13 dnsmasq[30138]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth
Dec 11 21:16:13 dnsmasq[30138]: asynchronous logging enabled, queue limit is 5 messages
Dec 11 21:16:13 dnsmasq-dhcp[30138]: DHCP, IP range 192.168.1.2 -- 192.168.1.254, lease time 1d
Dec 11 21:16:13 dnsmasq-dhcp[30138]: DHCP, sockets bound exclusively to interface br0
Dec 11 21:16:13 dnsmasq[30138]: read /etc/hosts - 5 addresses
Dec 11 21:16:13 dnsmasq[30138]: using nameserver 64.140.114.23#53
Dec 11 21:16:13 dnsmasq[30138]: using nameserver 64.140.114.22#53
Dec 11 21:16:13 dnsmasq[30138]: using nameserver 64.140.114.21#53
Dec 11 21:16:43 dnsmasq-dhcp[30138]: DHCPINFORM(br0) 192.168.1.227 00:24:2c:ac:6a:8e
Dec 11 21:16:43 dnsmasq-dhcp[30138]: DHCPACK(br0) 192.168.1.227 00:24:2c:ac:6a:8e
Dec 11 21:18:14 dnsmasq-dhcp[30138]: DHCPINFORM(br0) 192.168.1.227 00:24:2c:ac:6a:8e
Dec 11 21:18:14 dnsmasq-dhcp[30138]: DHCPACK(br0) 192.168.1.227 00:24:2c:ac:6a:8e
@@ Dec 11 21:19:16 WAN Connection: WAN was restored.
got another disconnect again today.
Dec 11 22:17:00 WAN Connection: ISP's DHCP did not function properly.
Dec 11 22:17:00 stop_nat_rules: apply the redirect_rules!
Dec 11 22:17:06 dnsmasq[2814]: exiting on receipt of SIGTERM
Dec 11 22:17:07 dnsmasq[3121]: started, version 2.67 cachesize 1500
Dec 11 22:17:07 dnsmasq[3121]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth
Dec 11 22:17:07 dnsmasq[3121]: asynchronous logging enabled, queue limit is 5 messages
Dec 11 22:17:07 dnsmasq-dhcp[3121]: DHCP, IP range 192.168.1.2 -- 192.168.1.254, lease time 1d
Dec 11 22:17:07 dnsmasq-dhcp[3121]: DHCP, sockets bound exclusively to interface br0
Dec 11 22:17:07 dnsmasq[3121]: read /etc/hosts - 5 addresses
Dec 11 22:17:07 dnsmasq[3121]: using nameserver 64.140.114.23#53
Dec 11 22:17:07 dnsmasq[3121]: using nameserver 64.140.114.22#53
Dec 11 22:17:07 dnsmasq[3121]: using nameserver 64.140.114.21#53
Dec 11 22:17:07 WAN Connection: WAN was restored.
I checked my thompson logs to find clues. the only stuff i see are
Wed Dec 11 10:52:07 2013 Critical (3) Received Response to Broadcast Maintenance Request, But no Un...
Time Not Established Warning (5) DHCP WARNING - Non-critical field invalid in response ;CM-MAC...
Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=c4:27:95:0a...
Tue Dec 10 17:42:31 2013 Critical (3) Received Response to Broadcast Maintenance Request, But no Un...
Time Not Established Critical (3) DHCP FAILED - Discover sent, no offer received;CM-MAC=c4:27:9...
Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/Q...
Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC f...
Can you tell us what you have tried so far on your end to resolve the issue, besides talking to your ISP?
Does this happen when you are connected to your modem directly from your PC?
What make and model of modem do you have?
Any info on signal strength of your modem with your ISP, etc etc?
Would be helpful to have as much info as possible.
Im only asking because I started having similar issues 2 weeks before buying Asus router. At the end of the day it turned out to be a bad modem (it died few days ago) and my cable company gave me a different brand of modem. And I no longer have any issues.
Thanks.
Seeing the errors related to QAM, it looks like an issue with either the ISP or the modem itself, as the modem is unable to connects its channels with the ISP. This would probably be visible by flashing lights on your modem while it occurs (I have a DCM475 myself BTW).
i connected directly to the cable with my vista machine and it has been stable for last 2 days. no disconnects at all. not a single drop on the ping for 2 days.
now, i am going to start this experiment next week by resetting my firmware and restoring to factory settings and post what i find.
i have a feeling that once you set the router to do dsl, you cannot switch to cable and vice versa without doing factory reset. I am just basing this on my challenges with the primus dsl until i did the factory reset.
