Can someone explain/confirm what they think is happening with dns here.
I am using dnscrypt with opendns to make use of parental controls blocking certain sites for the kids based on what I specify in my opendns profile. The DNS settings under wan are set to opendns servers but I believe this has no effect when dnscrypt is being used. çIs that bit correct (This all works as expected for normal LAN clients.)
Dns settings on my routers vpn client set to strict
VPN policy based routing is in place directing my tablet over the vpn to get round geo blocking. In relation to my tablet this is what is confusing me. When I run a dnsleak test the results are that I am using open dns servers and not my vpn providers however any filtering that I have in place per my opendns settings do not take effect for the tablet so….
In my mind this means that opendns is being used per the wan/dnscrypt settings but the request is getting sent through the vpn hence opendns don’t see my wan ip and I don’t get any filtering. <= does this sound plausible??
Also does this mean that the dns request for the tablet is not going through the dnscrypt tunnel with these settings, is there a way to check this??
If I use dns filter and force use of the router dns for the tablet via custom entry with the ip of my router dns leak returns opendns servers as expected and I do get filtering. <= edit after more testing tonight, no I dont.
I had previously asked if when using dnsfilter to force my vpn provider dns settings for vpn for certain lan clients like my tablet, did the dns request get sent down the tunnel or over the wan and I was told most likely over the vpn. ç does this still apply in the above scenario?
Many thanks
Many thanks
