OFark
Hoping someone with more experience than I can help.
The History:
Some time ago I upgraded to the aforementioned Asus AX86U with Merlins FW, to solve some wireless issues I was having with an older router. It's been great until Virgin upgraded my internet from 350Mb to 1Gb, accompanied by a new Router. Initially, everything was fine, but then after a few days my connection deteriorated (more on that later), I restarted everything and it was all back to normal. For a few days. Then connection issues, restart the router, back to fine. A few days later, repeat. And again, only this time I restarted my PC, no change, restarted Virgin's Router, no change, restarted the Asus AX86U, back to fine again.
The Specs:
The Virgin Router is their latest Super Hub 4, in Modem mode.
The Router is the Asus AX86U FW: 386.3.2
Everything in consideration is wired. CAT5e
Speedtest on the router won't pass 700Mbps when the PC will record 950Mbps (both when everything is ok)
50Mbps up on both.
The Connection Issue:
Speedtest down drops to 80Mbps (Both router and multiple PC's) whilst the upload remains at 50Mbps
Apparently, my voice sounds digitally choppy to other gamers (Xbox/PS5) and they occasionally cut out for me, but never distorted.
In my Teams meetings, my camera looks really bad quality, like it's making up for poor lighting, voices often go into what I would describe sounds like slow motion.
In some games, I get really bad rubber-banding.
The Router logs don't say anything that jumps out at me, but I'm not sure what I'm looking for. I do get: nf_conntrack: expectation table full, but following that around in this forum, I seem to be the only one experiencing slow down.
Worth noting:
I am using Diversion
I am maintaining a VPN tunnel out to Nord, for certain clients, but not this PC.
I am using a VPN Server, on the router, for my phone to connect back in again.
Hardware or software reset fixes the problem for the same length of time.
CPU and RAM are not maxed out.
What I need help with:
I am inclined to believe the problem is with the router, simply because resetting it seems to cure the problem for a few days. But I appreciate that the new Virgin router has triggered the issue, and I am open to suggestions, but I need proof if I am going back to Virgin with an issue. Otherwise, I am looking for something to try on the router, or ways to diagnose the problem, things to look for in the log, or settings etc.
Thanks in advance.
The History:
The Specs:
50Mbps up on both.
Worth noting:
Thanks in advance.
