Jan 1 01:00:06 syslogd started: BusyBox v1.20.2
Jan 1 01:00:06 kernel: klogd started: BusyBox v1.20.2 (2014-06-06 16:30:42 EDT)
Jan 1 01:00:06 kernel: start_kernel
Jan 1 01:00:06 kernel: Linux version 2.6.22.19 (root@asus) (gcc version 4.2.4) #1 Fri Jun 6 16:31:19 EDT 2014
Jan 1 01:00:06 kernel: CPU revision is: 00019749
Jan 1 01:00:06 kernel: Determined physical RAM map:
Jan 1 01:00:06 kernel: memory: 07fff000 @ 00000000 (usable)
Jan 1 01:00:06 kernel: memory: 08000000 @ 87fff000 (usable)
Jan 1 01:00:06 kernel: Built 1 zonelists. Total pages: 585216
Jan 1 01:00:06 kernel: Kernel command line: root=/dev/mtdblock2 noinitrd console=ttyS0,115200
Jan 1 01:00:06 kernel: Primary instruction cache 32kB, physically tagged, 4-way, linesize 32 bytes.
Jan 1 01:00:06 kernel: Primary data cache 32kB, 4-way, linesize 32 bytes.
Jan 1 01:00:06 syslog: module ledtrig-usbdev not found in modules.dep
Jan 1 01:00:06 syslog: module leds-usb not found in modules.dep
Jan 1 01:00:06 kernel: Synthesized TLB refill handler (20 instructions).
Jan 1 01:00:06 kernel: Synthesized TLB load handler fastpath (32 instructions).
Jan 1 01:00:06 kernel: Synthesized TLB store handler fastpath (32 instructions).
Jan 1 01:00:06 kernel: Synthesized TLB modify handler fastpath (31 instructions).
Jan 1 01:00:06 kernel: PID hash table entries: 2048 (order: 11, 8192 bytes)
Jan 1 01:00:06 kernel: CPU: BCM5300 rev 1 pkg 0 at 600 MHz
Jan 1 01:00:06 kernel: Using 300.000 MHz high precision timer.
Jan 1 01:00:06 kernel: console [ttyS0] enabled
Jan 1 01:00:06 kernel: Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Jan 1 01:00:06 kernel: Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Jan 1 01:00:06 kernel: Memory: 238608k/131068k available (2572k kernel code, 22624k reserved, 515k data, 196k init, 131072k highmem)
Jan 1 01:00:06 kernel: Mount-cache hash table entries: 512
Jan 1 01:00:06 kernel: NET: Registered protocol family 16
Jan 1 01:00:06 kernel: PCI: Initializing host
Jan 1 01:00:06 kernel: PCI: Reset RC
Jan 1 01:00:06 init-start: Init start script finished
Jan 1 01:00:07 kernel: PCI: Initializing host
Jan 1 01:00:07 kernel: PCI: Reset RC
Jan 1 01:00:07 kernel: PCI: Fixing up bus 0
Jan 1 01:00:07 kernel: PCI/PCIe coreunit 0 is set to bus 1.
Jan 1 01:00:07 kernel: PCI: Fixing up bridge
Jan 1 01:00:07 kernel: PCI: Enabling device 0000:01:00.1 (0004 -> 0006)
Jan 1 01:00:07 kernel: PCI: Fixing up bus 1
Jan 1 01:00:07 kernel: PCI/PCIe coreunit 1 is set to bus 2.
Jan 1 01:00:07 kernel: PCI: Enabling device 0000:02:00.1 (0004 -> 0006)
Jan 1 01:00:07 kernel: PCI: Fixing up bus 2
Jan 1 01:00:07 kernel: NET: Registered protocol family 2
Jan 1 01:00:07 kernel: Time: MIPS clocksource has been installed.
Jan 1 01:00:07 kernel: IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
Jan 1 01:00:07 kernel: TCP established hash table entries: 16384 (order: 5, 131072 bytes)
Jan 1 01:00:07 kernel: TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
Jan 1 01:00:07 kernel: TCP: Hash tables configured (established 16384 bind 16384)
Jan 1 01:00:07 kernel: TCP reno registered
Jan 1 01:00:07 kernel: highmem bounce pool size: 64 pages
Jan 1 01:00:07 kernel: squashfs: version 3.2-r2 (2007/01/15) Phillip Lougher
Jan 1 01:00:07 kernel: io scheduler noop registered (default)
Jan 1 01:00:07 kernel: HDLC line discipline: version $Revision: 4.8 $, maxframe=4096
Jan 1 01:00:07 kernel: N_HDLC line discipline registered.
Jan 1 01:00:07 kernel: Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing disabled
Jan 1 01:00:07 kernel: serial8250: ttyS0 at MMIO 0xb8000300 (irq = 8) is a 16550A
Jan 1 01:00:07 kernel: serial8250: ttyS1 at MMIO 0xb8000400 (irq = 8) is a 16550A
Jan 1 01:00:07 kernel: PPP generic driver version 2.4.2
Jan 1 01:00:07 kernel: MPPE/MPPC encryption/compression module registered
Jan 1 01:00:07 kernel: NET: Registered protocol family 24
Jan 1 01:00:07 kernel: PPTP driver version 0.8.5
Jan 1 01:00:07 kernel: Physically mapped flash: Found 1 x16 devices at 0x0 in 16-bit bank
Jan 1 01:00:07 kernel: Amd/Fujitsu Extended Query Table at 0x0040
Jan 1 01:00:07 kernel: Enabling Spansion 65nm mode, writesize = 512 bytes
Jan 1 01:00:07 kernel: Physically mapped flash: CFI does not contain boot bank location. Assuming top.
Jan 1 01:00:07 kernel: number of CFI chips: 1
Jan 1 01:00:07 kernel: cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
Jan 1 01:00:07 kernel: Flash device: 0x2000000 at 0x1c000000
Jan 1 01:00:07 kernel: Creating 5 MTD partitions on "Physically mapped flash":
Jan 1 01:00:07 kernel: 0x00000000-0x00040000 : "pmon"
Jan 1 01:00:07 kernel: 0x00040000-0x01fe0000 : "linux"
Jan 1 01:00:07 kernel: 0x001757f4-0x01a00000 : "rootfs"
Jan 1 01:00:07 kernel: 0x01fe0000-0x02000000 : "nvram"
Jan 1 01:00:07 kernel: 0x01a60000-0x01fe0000 : "jffs2"
Jan 1 01:00:07 kernel: Found an serial flash with 0 0KB blocks; total size 0MB
Jan 1 01:00:07 kernel: sflash: found no supported devices
Jan 1 01:00:07 kernel: dev_nvram_init: _nvram_init
Jan 1 01:00:07 kernel: sdhci: Secure Digital Host Controller Interface driver
Jan 1 01:00:07 kernel: sdhci: Copyright(c) Pierre Ossman
Jan 1 01:00:07 kernel: u32 classifier
Jan 1 01:00:07 kernel: OLD policer on
Jan 1 01:00:07 kernel: Netfilter messages via NETLINK v0.30.
Jan 1 01:00:07 kernel: nf_conntrack version 0.5.0 (2048 buckets, 16384 max)
Jan 1 01:00:07 kernel: ipt_time loading
Jan 1 01:00:07 kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Jan 1 01:00:07 kernel: net/ipv4/netfilter/tomato_ct.c [Jun 6 2014 16:31:18]
Jan 1 01:00:07 kernel: ipt_account 0.1.21 : Piotr Gasidlo <quaker@barbara.eu.org>,
http://code.google.com/p/ipt-account/
Jan 1 01:00:07 kernel: NET: Registered protocol family 1
Jan 1 01:00:07 kernel: NET: Registered protocol family 10
Jan 1 01:00:07 kernel: ip6_tables: (C) 2000-2006 Netfilter Core Team
Jan 1 01:00:07 kernel: NET: Registered protocol family 17
Jan 1 01:00:07 kernel: 802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
Jan 1 01:00:07 kernel: All bugs added by David S. Miller <davem@redhat.com>
Jan 1 01:00:07 kernel: VFS: Mounted root (squashfs filesystem) readonly.
Jan 1 01:00:07 kernel: Freeing unused kernel memory: 196k freed
Jan 1 01:00:07 kernel: Warning: unable to open an initial console.
Jan 1 01:00:07 kernel: ctf: module license 'Proprietary' taints kernel.
Jan 1 01:00:07 kernel: et_module_init: passivemode set to 0x0
Jan 1 01:00:07 kernel: et_module_init: et_txq_thresh set to 0x400
Jan 1 01:00:07 kernel: bcm_robo_enable_switch: EEE is disabled
Jan 1 01:00:07 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.30.163.2002 (r382208)
Jan 1 01:00:07 kernel: wl_module_init: passivemode set to 0x0
Jan 1 01:00:07 kernel: PCI: Enabling device 0000:01:01.0 (0000 -> 0002)
Jan 1 01:00:07 kernel: eth1: Broadcom BCM4331 802.11 Wireless Controller 6.30.163.2002 (r382208)
Jan 1 01:00:07 kernel: PCI: Enabling device 0000:02:01.0 (0000 -> 0002)
Jan 1 01:00:07 kernel: eth2: Broadcom BCM4331 802.11 Wireless Controller 6.30.163.2002 (r382208)
Jan 1 01:00:07 kernel: Algorithmics/MIPS FPU Emulator v1.5
Jan 1 01:00:07 kernel: JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
Jan 1 01:00:07 kernel: usbcore: registered new interface driver usbfs
Jan 1 01:00:07 kernel: usbcore: registered new interface driver hub
Jan 1 01:00:07 kernel: usbcore: registered new device driver usb
Jan 1 01:00:07 kernel: SCSI subsystem initialized
Jan 1 01:00:07 kernel: Initializing USB Mass Storage driver...
Jan 1 01:00:07 kernel: usbcore: registered new interface driver usb-storage
Jan 1 01:00:07 kernel: USB Mass Storage support registered.
Jan 1 01:00:07 kernel: ufsd: driver (8.6 U86_r187446_b122, LBD=ON, acl, ioctl, rwm, ws, sd) loaded at c0286000
Jan 1 01:00:07 kernel: NTFS (with native replay) support included
Jan 1 01:00:07 kernel: optimized: speed
Jan 1 01:00:07 kernel: Build_for__asus_n66u_2011-10-27_U86_r187446_b122
Jan 1 01:00:07 kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Jan 1 01:00:07 kernel: ehci_hcd 0000:00:04.1: EHCI Host Controller
Jan 1 01:00:07 kernel: ehci_hcd 0000:00:04.1: new USB bus registered, assigned bus number 1
Jan 1 01:00:07 kernel: ehci_hcd 0000:00:04.1: EHCI Fastpath: New EHCI driver starting
Jan 1 01:00:07 kernel: ehci_hcd 0000:00:04.1: irq 6, io mem 0x18004000
Jan 1 01:00:07 kernel: ehci_hcd 0000:00:04.1: USB 0.0 started, EHCI 1.00
Jan 1 01:00:07 kernel: usb usb1: configuration #1 chosen from 1 choice
Jan 1 01:00:07 kernel: hub 1-0:1.0: USB hub found
