Well that makes more sense. Scary that someone at Asus knows the term "Hz" but doesn't understand the definition, but that's a different issue.The documentation is wrong. It's 12 requests per minute, one every 5 seconds. This means it's 0.2Hz.
Mystery deepening a bit - the router ended up restarting itself a couple of minutes later with kernel errors complaining about nvram corruption, and post recovery the lease time showed as a day - same setting I have for the router's dhcp server to my lan. So now I'm not sure if it's router hardware or a bad config, or there is a bug with the handling of the dhcp renewal. I will factory reset today and debug further, and follow up when I've got a conclusion. Still feels like I'm on to something with the renewal cycle though...the lease had been changed to only 1 hour!!!! So, my hypothesis is that the isp changed a policy, and either the cable modem or the Asus somehow got the old lease time stuck.
Update:I was having the same problem with my old AC68U repeatedly dropping the WAN connection. The problem for me began in mid-Aug, and I've been working on troubleshooting it since. My ISP, Rogers Communications, checked external wiring and swapped the Hitron CODA-8562 that they supplied, but to no avail. When the problem started, I tried re-flashing the firmware and doing an M & M setup, still no joy. I decided that perhaps my 3-year-old AC68U was faulty, so I decided to buy a new router. I ended up purchasing the GT-AX11000 because that was what I could get locally that also had a good rating on the SNB Charts. Still no joy. Rogers convinced me that the CODA was legacy gear on their network and that I needed the newer "Ignite" modem they were offering (actually an Arris XB7), so I caved and swapped for the more recent gear and a slightly higher monthly fee. Still no joy. Then I found this thread, turned off the network monitoring function (Administration > System > Basic Config. Over the last 24 h internet access has remained steady and fast, so I'm hopeful. I'll update this thread with any other newsworthy items over the next few days. If all goes well, I will be installing the latest version of Merlin in a month or so.
Thanks for the great information, everyone.
I am having similar issues with a AC68U to everyone in this thread and disabled DNS and Ping monitoring with no effect. Merlin version: 386.3_2.Update:
15 days and I haven't needed to restart any of my network hardware! I can say that disabling the DNS or Ping monitoring of my internet connection solved the problem for me. Additionally, I was able to install my old AC68U as an AI Mesh node to improve coverage in an area of my home where previously the coverage was OK, but not great. All working well.
Thanks to everyone who contributed to this thread. @LD&D, I am going to add disabling this feature to my M&M config procedure. Might be worthwhile considering adding this to your M&M post as well.![]()
We use essential cookies to make this site work, and optional cookies to enhance your experience.
