Want to add a folder in /jffs/ but it's in read only (Need JFFS expert)
A bit of a long shot, but have you tried mounting it manually?
mount -t jffs2 /dev/mtdblock4 /jffs
Here is the output:
ASUSWRT-Merlin RT-AC3200 384.10-2 Wed Apr 3 22:29:42 UTC 2019
xxx@RT-AC3200-45F0:/tmp/home/root# mount -t jffs2 /dev/mtdblock4 /jffs
mount: mounting /dev/mtdblock4 on /jffs failed: Input/output error
Someone posted earlier today (or I read something old today) about mounting a usb stick as /jffs to avoid wear and tear or corrupt blocks. May be an alternative.
Another long shot, but if you follow the amtm Step-by-Step method here, do you have any success?
https://www.snbforums.com/threads/amtm-step-by-step-install-guide-l-ld.56237/#post-483421
If not, where is it failing for you, specifically?
I had to stop here:
xxx@RT-AC3200-45F0:/tmp/home/root# curl -Os https://raw.githubusercontent.com/decoderman/amtm/master/amtm && sh amtm
_
____ ____ | |_ ____
/ _ | \| _)| \
( ( | | | | | |__| | | |
\_||_|_|_|_|\___)_|_|_|
Do you want to install amtm
the SNBForum Asuswrt-Merlin Terminal Menu?
_____________________________________________
Continue? [1=Yes e=Exit] 1
mkdir: can't create directory '/jffs/scripts': Read-only file system
cp: can't create '/jffs/scripts/amtm': No such file or directory
chmod: /jffs/scripts/amtm: No such file or directory
amtm: exec: line 1806: /jffs/scripts/amtm: not found
I had to stop here:
_
____ ____ | |_ ____
/ _ | \| _)| \
And to be doubly sure, you enabled step 2. Click 'Yes' to the 'Enable JFFS custom scripts and configs' option?
Then hit 'Apply' and then reboot the router?
If yes to all the above, then the router has a hardware fault. :(
Hopefully, just a simple step was missed and we're narrowing it down for you to have a working router. :)
Amtm can't install itself since his JFFS partition is not mountable.
Actually, looks like the flash_erase applet is there, so you could give this a try:
flash_erase -u -j /dev/mtd4 0 0
Yes both where selected.
It says command not found, i did a search and was not able to fid it.
kronyx@RT-AC3200-45F0:/tmp/home/root# flash_erase -u -j /dev/mtd4 0 0
-sh: flash_erase: not found
kronyx@RT-AC3200-45F0:/tmp/home/root# cd ..
kronyx@RT-AC3200-45F0:/# cd ..
kronyx@RT-AC3200-45F0:/# find -name flash
Have you tried flashing the firmware through Recovery Mode instead of through the router's web interface? (although I can't think why that would be any different)
Could be model-specific then (I see the command is actually there on my RT-AX88U, not just a busybox applet).
I tried your's and still not found, i was already at the root / ;-)
Did you ever get this resolved? My AC3100 is having the same issue. Tried manually mounting the partition but got the same IO error as you.
I noticed my logging was complaining about a bad block, so, I'm thinking the NAND might be toast in my router. Everything else seems to work, however.
