Want to switch to Merlin's firmware, guide available?
BeachBum
I want to switch over to Merlins firmware for my AC3200 to take advantage of the more advanced VPN Client features (I want to VPN only 1 device and not everything on the network).
Is there a guide for how to flash my router? Do/Can I back things up? What if there is a problem during the flash, does my router get bricked? Can I revert to the stock firmware if/when I want to?
Ah, thanks RMerlin.
One question: The AC3200 isn't listed in the supported devices on that link, but it is listed here on this site's thread. Can I take it that it IS supported?
I see it listed under Supported Devices. Which page are you looking at?
Duh, I see it now. My wife always complains I couldn't see a barn right in front of me :)
You flash it has normal.
You download the zip file. https://www.mediafire.com/folder/bkfq2a6aebq68/Asuswrt-Merlin
You unzip the file
and you flash it with the .trx = http://192.168.1.1/Advanced_FirmwareUpgrade_Content.asp
Finally if your router act weird after that "Factory default reset" http://192.168.1.1/Advanced_SettingBackup_Content.asp
and reconfig
Tadam! :)
Thanks! Very helpful on both of these. I will most likely flash tonight...
