Was I being Hacked?
JT Strickland
I was doing a periodic check on my router, and saw there were 3 then 2 then 1 then 0 UNDEF users logged into my VPN server, and only one person, my accountant, is supposed to come in that door.
I checked my log, and it was filled with these, with varying addresses:
Sep 28 04:38:52 RT-AX86U-CB28 ovpn-server1[5343]: 45.164.16.135:80 TLS: Initial packet from [AF_INET]45.164.16.135:80 (via [AF_INET].xxx.xxx.xxx%eth0), sid=xxxxxxxx xxxxxxxx
Sep 28 04:39:52 RT-AX86U-CB28 ovpn-server1[5343]: 45.164.16.135:80 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Sep 28 04:39:52 RT-AX86U-CB28 ovpn-server1[5343]: 45.164.16.135:80 TLS Error: TLS handshake failed
Sep 28 04:39:52 RT-AX86U-CB28 ovpn-server1[5343]: 45.164.16.135:80 SIGUSR1[soft,tls-error] received, client-instance restarting
I turned off access to the server, then turned off the server. Scared me, never have seen that before. About all of them were from port 5343, or I assume that's what that is, but the IP varied.
Am I got?
It seems somebody found your port and is probing it. Everything is working as intended (TLS negotiation failed) because they didn't authenticate and weren't permitted a connection.
When this happened to me I switched external ports (to a higher port number).
Thanks, I will try that. I knew that had "wrong" wrote all over it.
Knowing me, I probably posted that port number.
Don't trust accountants!
You're using port 80. Tons of bots will scan ports 80/443, so that's a bad idea.
I thought I had changed that, but I will now!
I expected Skynet would catch it, but I suppose it didn't because they were coming in through openvpn.
