Was my router's username and password hacked?
Yep, noticed that one also. Not a Linux guy though...can't find the location through SSH
Issue the ps command again. Is it still there and using the same port? If so, try going to https://www.grc.com/shieldsup and testing port 16161.
Yep... and it's open :-(
Port
Status Protocol and Application
16161
OPEN! Unknown Protocol for this port
Unknown Application for this port
10849 admin_ed 1136 S dropbear -p 192.168.1.1:22 -a -j -k
This is sort of interesting (and I think I see the bug) with the options '-a -j -k' it should be '-a' or '-j -k'
-j        Disable local port forwarding
-k        Disable remote port forwarding
-a        Allow connections to forwarded ports from any host
Bug or was it consciously altered?
Strange .... I've just checked my router (logged in remotely through OpenVPN). I also have both '-a' and '-j -k'. My Router was freshly updated to 380.64 just few days ago. I never detected any signs of infection yet. Here is the screenshot:
Just to clairify.....I think setting the conflicting options is a bug in the ASUS firmware.....not in dropbear.
I'v asked about the attribute interpretation sequence. Easier than going through the documentation...
I've been removing the 16161 port from IPtables (iptables -D INPUT -p tcp --dport 16161 -j ACCEPT), but guess what...every time after waiting a bit the IPtables entry to accept 16161 connections (ACCEPT tcp -- anywhere anywhere tcp dpt:16161) reappears again. Even when not saving the IPtables (service iptables_save)
There might be more alterations present.
I fully agree with you. Could you check in the code base since which version it appeared? Then most probably it spread in Merlin's FW and your fork.
Looks like the change came in with the 4th April 2016 merge with Asus GPL 380_2697?
My fork is OK.....just wrote a patch for Merlin. Looks like it came in with 380.59 (Colin got it)
