Rik Stigter
Hello!
My setup is as follows:
Everything else works, that is all other websites load without problems, although I have the impression that they are a bit slower than usual.
If, for testing purposes at such a time, I start a VPN (NordVPN, in my case) on a workstation/laptop everything works as is to be expected: fast. After a router-reboot: the same, but unfortunately only for the same 2-4 hours.
There is one other weird phenomenon and that is that I sometimes loose 5Ghz-connections, but they re-establish themselves if (big IF) I'm patient. I'm using both WiFi5 and WiFi6-adapters and all show this behaviour.
I have (diligently, if I may add), reset (M&M) both systems several times now, usually when upgrading the firmware. Before Unbound I used Diversion, but the problem persists no matter what.
My (I hope wrong ) ideas/conclusions so far are:
(Worse even: I'm considering flashing he AX88 with stock firmware. Huh.)
My ISP is showing an interest and they are sending me a new modem (well: router in bridge mode) which will arrive in a day or two. They even know about merlin-firmware (Hooray! Miracles do happen) and started looking at these pages when I called (even better). But they didn't come up with any better ideas than that, I'm afraid.
What is it that I'm overlooking?
- RT-AX88, running Merlin 384.15
- amtm
- Skynet v7.1.0
- Scribe v2.4.2
- Unbound Manager v2.07
- UiScribe v1.2.1
- Swap 2.0GB
- AiMesh RT-AC86, running Merlin 384.15
- There's 'nothing' wrong with DNS, because all other websites load as to be expected
- Memory is not an issue, for the same reason (it usually settles at about 80% max)
- All other performance indicators look normal (no CPU-hogs)
- There must be a Google-killer Gremlin somewhere (I'm not a great fan of Google myself, but I don't hate them or something. The thing is that my better half uses Google all the time and I don't want her upset!)
