Agarwal
I'm currently contemplating starting a business making NASes, and I would like to know what would potentially make you buy a NAS and what you would pay for it. This might be a good opportunity to make yourself heard regarding the features and specs you want in a NAS
This is what I envision:
Data protection features (this is mostly already developed and working):
Hardware, OS and apps:
Target retail price for the 4-bay NAS: 600$, 3 years warranty.
Would you buy it? If not, what is missing or what would make you buy it? Please assume excellent customer support, as this is certainly in my top 3 objectives.
Please make yourself heard!
/Edit:
- Mix & Match drives capability
- Automatic array grow on adding a new bigger drive or replacing a smaller one
- Independant file systems on each drives. This means that if you if you lose more than one drive in the array, the remaining drives can still be accessed and you don't lose data that's not on the failed drives.
- No special formatting or filesystem needed (there is a filesystem restriction if you want advanced features like automatic growing of the partition)
- NTFS support as a target filesystem; this means that you could plug your drive in your windows PC, format the drive, use it for some time, and then plug it in the NAS, and it would just work. Your data is now protected. In case of array failure, take the drive out of the NAS, plug it in your windows PC, and the data that was on that drive is still accessible.
- No initial clearing of the drive needed.
- Reading will only affect a single drive, unless you are reading a failed drive. This means that you can expect the read performance to be on par with the target drive.
- Write speed up to 200mb/s with an optional hardware add-in. Otherwise, write speed will necessarily be slower as the target drive's write speed and data protection needs to be factored in.
- Samba, FTP and NFS out of the box.
- If you have a 4-drives array and currently streaming (read-only) 1 file from 1 single drives, the other drives can spin down, making the device quite energy efficient for a read-intensive array.
- This is a dedicated, embedded NAS box running a custom firmware (probably based on linux like the others, but I have part of my system working in *BSD too)
- Something like the AMD E-350 CPU, along with 4GB of memory (upgradable) and 16GB of flash memory (upgradable).
- 4xUSB 3.0 ports
- 6.0 Gb/s SATA, 1 eSATA port
- HDMI and optical/analog audio output available (although not used by the stock firmware, but can be used by apps)
- PCI Express x16 slot (x4 bandwidth) for extensibility
- (External drives can be used in the main array)
- Ultra quiet machine and energy-efficient machine (<50 watts under full load)
- 2-4-6 removable (or not? vote on it) bays configuration
- Apps system: in order to be able to provide support for apps, I would use the App Store model, with apps typically selling for 1-10$. Some of the apps I can see:
- VOIP server/gateway
- usb printer spool
- bittorrent client
- web server/php/mysql with installable packages (blogs, cms, etc)
- Settop box software
- UPnP/DNLA server
- Music player / streamer / jukebox
- Router
- Video transcoding (prolly not on the fly, but still)
- Home automation center
- Simple Remote access to files
- DVD/BluRay ripper
- iSCSI target, ADS support (although all business-oritented features would probably also be packaged in a separate product)
- etc, etc, etc
- You would have root access to the box if you wanted to, meaning that you wouldn't *have* to buy apps and get vendor support if the time needed to install/maintain those apps is not worth 1-10$ to you
- I would also allow third-party developers to publish their app to the app store, after being reviewed. Developers would receive a percentage of the sales of their app.
/Edit:
- Added precision on USB, SATA and external drives.
- Added precision on single-drive streaming and spinning down other drives.
