tl;dr: what do the 4 different antennas on the RT-AX88U do ?
Background:
I'm strongly considering consolidating my 2x RT-AX88U devices (1x router, 1xAP) to just one.
We live in an 1800 sf single story home with lots of attic access. The layout is sprawling and there are devices on the exterior that need wifi (sprinklers, switches, cameras). A single centralized router isn't enough yet having 2x routers seems like overkill. The thought occurred to me that the antenna placement might be the solution.
So I experimented with coaxifi to put one antenna up into the attic then played around with different antenna ports, using rudimentary test of leaving the extended antenna in the attic then using Wifi Inspector to compare relative signal strength of the various ports. I noticed that the rear left antenna (nearest the power button) seems to extend the 2.4 GHz signal, while the other rear antenna (nearest the USB port) seems to extend the 5 GHz. It wasn't clear if the flanking antennas extended much of anything. I've disabled the wifi on node 2 and now get a solid 5 GHz signal in the otherwise hard-to-reach corner of the home.
A bit of mixed hope here - what would happen if I simply extended all 4 antennas to my attic using a simple RP-SMA Male To Female Wifi Antenna Connector extension (~10M or so)? The difficulty being that I would like to have all 4 antennas broadcast both bands. Assuming there's no insertion loss from the extension, of course....
Does anyone know what each of the antennas does, or do they all broadcast everything?
Background:
