What is the earliest script where the LAN (not WAN) will be up?
cmkelley
I have a separate time server on my network so if the LAN comes up before the WAN I can update the time from it at the earliest opportunity. I've read https://github.com/RMerl/asuswrt-merlin/wiki/User-scripts, but it doesn't really say which of those is "first". It's got a static IP so I don't need any DNS services.
Does the LAN even come up before the WAN? Is a loop in init-start the best way?
I wouldn’t go with a blocking loop (as there is a 120 second execution time limit on the start scripts), but a forked/demonised script spawned from init is probably your best bet.
The earliest script called is init-start but even though it executes early it may not be early enough.
As far as I can tell, the LAN is not up when init-start runs. Judging by the fact that there is a wan-start script, the WAN isn't.
