What;s going on with my Kernel
Nas.CloudBusinessPortal
With a Asus RT88U Pro using 388.8.4 firmware. Yes it the kernel, i get it.
Jan 6 04:02:17 kernel: eth0 (Int switch port: 6) (Logical Port: 6) (phyId: 13) Link DOWN.
Jan 6 04:02:17 kernel: ^[[0;33;41mFCACHE ERROR: fc_config_mcast_group: Mcast: client has already JOINed the mcast group (duplicate JOIN)^[[0m
Jan 6 04:02:17 kernel: Mcast: new client info: group_addr<239.255.255.251> src_addr<0.0.0.0> is_ssm<0> tx_dev_p<ffffffc029fe6000> wlinfo<0000> client_type<0> MAC<9c:8e:cd:00:14:85> rtp_seq_chk<0>
Jan 6 04:02:17 kernel: rtp_seq_chk<0> mcast_excl_udp_port<0>
Jan 6 04:02:17 kernel: Mcast: new client: matches with: mcast_group<3> client_id<1>
Jan 6 04:02:17 kernel: ^[[0;33;41m[ERROR mcast] bcm_mcast_clientinfo_node_add,843: blog_activate failure^[[0m
Jan 6 04:02:17 kernel: ^[[0;33;41m[ERROR mcast] bcm_mcast_fc_flow_add,924: Error adding client info node^[[0m
Jan 6 04:02:17 kernel: is_ssm 0 grp 239.255.255.251 src 0.0.0.0
Jan 6 04:02:17 kernel: mcast_exclude_udp_port 0x0 rtp seq check 0
Jan 6 04:02:17 kernel: ***Client List***
Jan 6 04:02:17 kernel: to_accel_dev eth5 wl info 0x0 clientmac 9c:8e:cd:1d:e8:c1
Jan 6 04:02:17 kernel: ***Rx Info list***
Jan 6 04:02:17 kernel: rxinfo blog_p 0xffffffc029e82a80
Jan 6 04:02:17 kernel: ^[[0;33;41m[ERROR mcast] bcm_mcast_blogrule_vlan_process,319: Unable to create flow, continue^[[0m
Jan 6 04:02:18 kernel: ^[[0;33;41mFCACHE ERROR: fc_config_mcast_group: Mcast: client has already JOINed the mcast group (duplicate JOIN)^[[0m
Jan 6 04:02:18 kernel: Mcast: new client info: group_addr<239.255.102.18> src_addr<0.0.0.0> is_ssm<0> tx_dev_p<ffffffc029fe6000> wlinfo<0000> client_type<0> MAC<68:14:01:44:d2:81> rtp_seq_chk<0>
Jan 6 04:02:18 kernel: rtp_seq_chk<0> mcast_excl_udp_port<0>
Jan 6 04:02:18 kernel: Mcast: new client: matches with: mcast_group<1> client_id<1>
Jan 6 04:02:18 kernel: ^[[0;33;41m[ERROR mcast] bcm_mcast_clientinfo_node_add,843: blog_activate failure^[[0m
Jan 6 04:02:18 kernel: ^[[0;33;41m[ERROR mcast] bcm_mcast_fc_flow_add,924: Error adding client info node^[[0m
Jan 6 04:02:18 kernel: is_ssm 0 grp 239.255.102.18 src 0.0.0.0
Jan 6 04:02:18 kernel: mcast_exclude_udp_port 0x0 rtp seq check 0
Jan 6 04:02:18 kernel: ***Client List***
Jan 6 04:02:18 kernel: to_accel_dev eth5 wl info 0x0 clientmac 4c:72:b9:d4:fd:d0
Jan 6 04:02:18 kernel: ***Rx Info list***
Jan 6 04:02:18 kernel: rxinfo blog_p 0xffffffc029e94fc0
Jan 6 04:02:18 kernel: ^[[0;33;41m[ERROR mcast] bcm_mcast_blogrule_vlan_process,319: Unable to create flow, continue^[[0m
Jan 6 04:02:20 kernel: ^[[0;33;41mFCACHE ERROR: fc_config_mcast_group: Mcast: client has already JOINed the mcast group (duplicate JOIN)^[[0m
Jan 6 04:02:20 kernel: Mcast: new client info: group_addr<239.255.255.253> src_addr<0.0.0.0> is_ssm<0> tx_dev_p<ffffffc029fe6000> wlinfo<0000> client_type<0> MAC<68:14:01:44:d2:81> rtp_seq_chk<0>
Jan 6 04:02:20 kernel: rtp_seq_chk<0> mcast_excl_udp_port<0>
Jan 6 04:02:20 kernel: Mcast: new client: matches with: mcast_group<34> client_id<1>
Jan 6 04:02:20 kernel: ^[[0;33;41m[ERROR mcast] bcm_mcast_clientinfo_node_add,843: blog_activate failure^[[0m
Jan 6 04:02:20 kernel: ^[[0;33;41m[ERROR mcast] bcm_mcast_fc_flow_add,924: Error adding client info node^[[0m
Jan 6 04:02:20 kernel: is_ssm 0 grp 239.255.255.253 src 0.0.0.0
Jan 6 04:02:20 kernel: mcast_exclude_udp_port 0x0 rtp seq check 0
Jan 6 04:02:20 kernel: ***Client List***
Jan 6 04:02:20 kernel: to_accel_dev eth5 wl info 0x0 clientmac 4c:72:b9:d4:fd:d0
Jan 6 04:02:20 kernel: ***Rx Info list***
Jan 6 04:02:20 kernel: rxinfo blog_p 0xffffffc029e20a80
Jan 6 04:02:20 kernel: ^[[0;33;41m[ERROR mcast] bcm_mcast_blogrule_vlan_process,319: Unable to create flow, continue^[[0m
Jan 6 04:03:11 kernel: eth0 (Int switch port: 6) (Logical Port: 6) (phyId: 13) Link Up at 2500 mbps full duplex
Jan 6 04:03:12 kernel: ^[[0;33;41mFCACHE ERROR: fc_config_mcast_group: Mcast: client has already JOINed the mcast group (duplicate JOIN)^[[0m
Jan 6 04:03:12 kernel: Mcast: new client info: group_addr<239.255.102.18> src_addr<0.0.0.0> is_ssm<0> tx_dev_p<ffffffc029fe6000> wlinfo<0000> client_type<0> MAC<68:14:01:44:d2:81> rtp_seq_chk<0>
Jan 6 04:03:12 kernel: rtp_seq_chk<0> mcast_excl_udp_port<0>
Jan 6 04:03:12 kernel: Mcast: new client: matches with: mcast_group<1> client_id<1>
Jan 6 04:03:12 kernel: ^[[0;33;41m[ERROR mcast] bcm_mcast_clientinfo_node_add,843: blog_activate failure^[[0m
Jan 6 04:03:12 kernel: ^[[0;33;41m[ERROR mcast] bcm_mcast_fc_flow_add,924: Error adding client info node^[[0m
Jan 6 04:03:12 kernel: is_ssm 0 grp 239.255.102.18 src 0.0.0.0
Jan 6 04:03:12 kernel: mcast_exclude_udp_port 0x0 rtp seq check 0
Jan 6 04:03:12 kernel: ***Client List***
Jan 6 04:03:12 kernel: to_accel_dev eth5 wl info 0x0 clientmac 4c:72:b9:d4:fd:d0
Jan 6 04:03:12 kernel: ***Rx Info list***
Jan 6 04:03:12 kernel: rxinfo blog_p 0xffffffc029e94fc0
Jan 6 04:03:12 kernel: ^[[0;33;41m[ERROR mcast] bcm_mcast_blogrule_vlan_process,319: Unable to create flow, continue^[[0m
Jan 6 04:03:12 dnsmasq[3587]: read /etc/hosts - 22 names
Jan 6 04:03:12 dnsmasq[3587]: read /jffs/addons/YazDHCP.d/.hostnames - 173 names
Jan 6 04:03:12 kernel: potentially unexpected fatal signal 6.
See attachment for full log
  • Asus Log.txt
