Ragpuss
hi all,
I have been searching but have not found an answer to what is likely a very noob question.
I have tried 4 different thumb drives to run the custom jffs scripts (entware etc’) and only my old USB2 8gb and 16gb seems to work !
When I tried a 128gb USB3 drive it just kept getting memory errors even when just trying to run simple shell commands. I then tried a USB3 64gb drive and that won’t even get recognised on router reboot, so I have to remove and reinsert the drive manualy.
I would like to mount a larger thumb drive but I don’t want to keep buying ones that don’t do the job.
Is there a rule to follow or a type of thumb drive that needs to be used ?
Both of the USB3 drives were of a good brand and supposed to be fast write and read USB3 speeds but my old slow USB2 are the only ones so far to work :/
As a note I put the USB3 drives into the USB3 port and my old USB2 drives into the USB2 port, does the USB2 port work better for the scripts ?
Any help here please ?
Thank you in advance.
