What VPN do you suggest?
I can't get it to work with IP/routing
@Tech9
I got problems connecting with this, should I edit "Content modification of Keys & Certificate]"?
I also will show you the advanced settings in the PNG file attached
Is your router in double NAT behind another? WAN IP public, private, CG-NAT?
VPN server configuration is few clicks only + export the configuration to the client. You don't need to edit anything, except perhaps the default port 1194.
Anyone who advertises on Amazon for a VPN voucher. Wouldnt trust
What about advertisements in Asuswrt?
I have the OpenVPN server running - almost on defaults, I have only changed the VPN access to both LAN and Internet. Exported the configuration file to my Linux Mint 21.2 client.
Installed the client on my Linux succesfully. But I can't connect to the VPN server? What did I do wrong?
The Best VPN I can recommend is to run your own - it's not that hard, and it's not that expensive...
It does require some knowledge on linux and networking, but one can get a free account on Oracle Public Cloud, and then clone Algo's TrailofBits...
Remember - with VPN's - if you don't own/control both ends, it's not private...
I was uninitiated, but I had a vps with openvpn access server set up 5 minutes after getting my server login.
It's easy. Why don't you give it a go? If it doesn't work for you then return the server for your money back. Don't be worried about trying something for free.
From the desk of an elder gent.
Nord is normally about $2/mo when you find some codes for discounts. The codes are always out there. When I renewed though I was a bit peeved due to them dropping the 3 year option.
Waiting soon some good code for nordvpn, 2 usd per month great price
