pinkfloyd1173
So I was wondering what a safe temp is for this router at the moment my temps are
2.4 GHz: 48°C - 5 GHz: 70°C - CPU: 76°C
Is this a normal temp???
I dont even use more then half the features on the router other than the QOS, and at the moment all that I am using is the pc to surf the web.
Just wondering guys, maybe if I put a laptop cooler underneath it it might cool it down???
