I think the only cheaper cables that might approach data center quality might be Cables2Go (Legrand), but it still isn't going to compare to Panduit, etc. If you want Panduit, search around amazon, there are some 3rd party sellers with ok prices, probably discontinued ones etc. Of course there is a chance you'll get a fake. Belden, Panduit, and Commscope are the 3 I usually see in data centers. Commscope generally considered cream of the crop if you're willing to shell out the $$. But again search around, you can probably find surplus or discontinued ones at cheaper prices.
For home use (patch cable, not in wall), I'd just buy Monoprice. If one out of 10 is bad, throw it away. Make sure it is decent gauge wire. Hell I've got some amazon basics and some brand called C&E that had a price mistake on amazon years ago that I bought a bunch of. Both work fine with 0 errors on the ports and full throughput (granted my LAN runs at 1 gig, but have used them for lab work with 10GBaseT without issue too).
As long as you stick with true UTP or STP round cable, not the flat or ultra thin or other garbage, and a good gauge, 26 or bigger, you should be perfectly fine. CCA transmits fine, the main reason for pure copper is that aluminum can wear out quicker if you are flexing or bending it a lot, and bend radius is a bit more of a concern. If you kink a copper cable, it'll probably be fine, but CCA a bit more likely to have some internal damage (but with stranded cable used in patch cords, even that is pretty unlikely). Hell one of these days they'll figure out how to coat some cheap paper or plastic with copper and that will be the new norm for cheap cables. The electricity travels on the outside, not the inside, the core is just for structure.
