Which is faster ?
Denna
I'm trying to connect an Asus RT-AC88U to a mobile hotspot for Internet access.
The hotspot supports USB 2.0 and 802.11ac up to 433 Mbps.
Which should be faster ?
USB connection from the router to the hotspot.
Connect the router to the hotspot through a wireless media bridge/extender via 5 GHz.​
The router''s USB can't be used for hotspot tethering.
thiggins,
Currently, the router running the current version of Asuswrt-Merlin is connected to the hotspot via USB and is working.​
What mobile hotspot are you using?
thiggins,
My apologies for my error.
Leave it alone. USB 3.0 will not limit your speed and will be more reliable than WiFi
I meant, what make/model of mobile hotspot. Might be nice to have as a backup solution for home.
Asus supports Android tethering, however your result might vary based on your actual device.
Wifi-based tethering (also known as "wireless client mode") is not supported.
