Which WiFi PCI adapter to get next?
Which one do you think I should go for?
  • ASUS PCE AX58
  • Fenvi AX200
  • Other (please write below)
Results are only viewable after voting.
Thank you so much for the responses,
my ISP speed is 200mbps download
20mb upload.
I agree an AX card is unnecessary like i mentioned, my router is AC 5ghz but I thought I would get an AX card to future proof my PC.
I do like the sound of that media bridge option, I assume it would pick up a solid signal to transmit to my PC LAN port - because my PCIe Asus AC-88 is able to pick up a good 5ghz signal where I am so that should mean a router would be able to do the same.
haha yes i know how it looks, I have tried something similar to that but was disappointed which is why I have opted for the ac88 due to its 4 x aerials.
Hello again
So I have been doing more research and looked into access point mode, repeater mode and media bridge mode options on ASUS routers.
I have decided to go with the rt 68 router as it is more in budget vs the rt 86.
can I just double check my understanding
I will have :
option 1:)
My old router acting as a modem only mode—>
Wired LAN connection to the ASUS 68 which is now on access point mode
(Essentially the main source of WiFi in the house)
Wireless connection to
A second ASUS rt 68 next to my pc (which is connected to the 1st rt 68 by WiFi)
Rj45 connection
Connection by rj45 from the 2nd ASUs rt68 to my PC.
Can other devices connect to this second router also via WiFi? Like in a mesh system kind Of way?
Or is it one or the other?
I know these old repeaters/extenders usually have LAN cable slots which allow wired connections in addition to WiFi signal that they transmit.
Or will this media bridge mode change that
Thanks!
