Wi-Fi 7 Multi Link Operation (MLO) discussion
@L&LD et al, it would be helpful to cite authoritative sources to back up your points.
Here is my contribution. Start around 8 minutes in.
At the end of the day - 11be will be like 11ax and 11ac... a subset of features that win on the cost/benefit scale...
I don't know many people that are willing to spend $300USD or more on a wifi router - did the reseach, been there, done that...
Increments - it's all good, but complexity equals cost, so the vendors will find the best middle path.
There's a lot of things in the specs for 11n/11ac/11ax that were never actually deployed...
Recall that the representatives in the 802.11 working groups - it's to their advantage to keep things going, otherwise they would be sitting on skid-row...
Enough do that it’s a billion dollar market in 2023. All of the Wifi 7 routers have been selling out constantly since April.
TP-Link can’t ship them over fast enough, and I think their ASP is around $400 a pop.
MLO isn't supported in the Intel 411 m.2 network card. At least, it's called "Intel® Double Connect Technology" from back then. Not the same thing, even if it superficially looks like MLO. Btw, this card was introduced in Q4 2021. A very long way off from the still uncertified WiFi 7 status of today.
Perhaps the communication breakdown centers on whether "MLO" means "multiple link operation" or "yet-to-be-ratified-Wifi-7-specific-implementation(s) of MULTIPLE LINK OPERATION". Using more than one link simultaneously /is/ multiple link operation. (One can readily do this with wires and fibers, too.) I don't believe the discussion, at this point, ever went beyond the general sense of it, unless it was until you started wanting it to be something either different or more specific.
Some more of my unantagonistically-inspired thoughts on the matter...
@thiggins, thank you for that link (even if it's from early 2022).
My 'authoritative sources' are logic and already defined terms regarding WiFi. And my insistence on not conflating cellular network 'similarities' with WiFi, and specifically, WiFi 7.
I will not be providing those authoritative sources, life's too short. Search is free for all.
It is not my misunderstanding that using an additional link (SSID, radio, etc.) in addition to another isn't going to affect one band's 'channel 100'.
I can't force Qbcd to learn anything here. But I can try to help him by proving his logic is faulty when he shows it to be so.
L&LD said:
It is impossible to aggregate 2.4GHz and 6GHz on Channel 100. You're misunderstanding how this works. There is no contamination as you're defining it.
I'll confess I'm too uninspired to trace my way back to the context so I'll merely go by recollection here. While following the discussion /I/ did not gather it was being even /implied/ that any different bands' channels would be aggregated _within_ /any/ specific channel or band. I feel that must've been an assumption on your part.
Also, I understood the "pollution" wasn't being attributed to any (other) channel-as-MLO-member, rather the "whatever-aggregate-/capability/" would be dragged down as a whole. I can't say whether I would've expressed the notion any more succinctly, but I completely understood the meaning and found it fairly represented. Which is kind of why my empuzzlement by your end of the interaction. You're correct in what you're saying, in my estimation, but the specific subtle points you've made were really made /against/ notions which hadn't been expressed, if that make sense.
Words fail me to describe the arrogance of those statements.
Yes, life is too short. Unfortunately, I have to moderate these forums, so can’t use the Ignore button as many others have done.
I'm sorry you see as arrogance what I see as simple logic. The ignore button is not a feature I use.
@glens, I put a lot of time into quoting each point I've made and also quoted each of Qbcd's responses. I don't know why they were deleted from my post. They made my point that logic is what is failing with the other person's responses.
When talking about a specific industry, the proper terminology should be used. I don't know why that is so hard to understand.
I'm not the only one trying to help Qbcd understand (Jansen3 tried also).
See the quotes below to see how confused our friend is here. The meaning is clear to me; he really believes that WiFi MLO is somehow equivalent to cellular behavior). It isn't.
On the "contamination" point - of course it does, if you're aggregating 2.4 GHz and 6 GHz onto my Channel 100, then you're introducing all the latency and signal strength issues of those links into the aggregated connection. Maybe MLO is smart enough to use the high-performance band as an anchor and manage the rest intelligently, but I don't trust it, much rather not introduce the extra variables. I prefer stability over speed. And moreover, MLO probably requires the same power limit on all bands, so now my Channel 100 has to go down to 24 dbm, which kills its main advantage. It'll need to be tested ultimately, but I don't see how it can be as good as using a single channel.
Ok, so for the record you are saying that MLO or CA in cellular networks is not adding or aggregating several channels together? You're so adamant about this being wrong that I am curious what you think the actual correct description of these technologies is, in general terms. I mean it's literally called "multi-link operation", I feel like it's pretty self-explanatory, but I could be missing something.
You’re asserting your opinion as facts. Stating that your opinion is logic and common sense implies that everyone else is an idiot.
In the real world, people cite other sources to back up their assertions. They don’t cite themselves as experts.
Saying WiFi 7 and cellular aggregation is similar is like saying that a round rock is an early bicycle.
“Qualcomm’s Vice President and General Manager of Mobile and Compute Connectivity Dino Bekis referred to multi-link capability as one of the core aspects of Wi-Fi 7 and suggested thinking of multi-link for Wi-Fi 7 as similar to how channel aggregation works in cellular networks.”
I guess the guy in charge of Wi-Fi 7 at Qualcomm is wrong then.
Not sure how anyone could see it as anything else, it's combining multiple frequencies to increase bandwidth.
It's not combining multiple frequencies to increase bandwidth. It's combining multiple links to increase bandwidth which is a huge difference. Did no one else see the video @thiggins provided? Each link/connection is still discrete. They are simply connected concurrently (in a few different and distinct ways) and used as much as possible.
While Qualcomm's vice president may have said that, that is not how it actually works. Qbcd said effectively the same thing which is what I'm trying to correct him on. Yes, 'the guy in charge of WiFi 7 at Qualcomm' is wrong, if that is what he said.
It may be easier for a layperson to understand that WiFi 7 is 'like' cellular. But it isn't, in practice.
@thiggins, I don't understand how or why you're using "condescension" here toward me. Even when I attempt to apologize and present my understanding, I'm wrong?
Has anyone viewed the video in full above that thiggins provided the link for? It is very clear WiFi 7 is not like a cellular network, at all.
It's not my opinion. This is a fact. The proof is in the video above. For those who need proof above what an individual may state based on knowledge and logic (and without having seen that video previously, but have read about WiFi 7 on other media).
This isn't debatable. And I'm not debating. I'm providing facts and people just refuse to accept them. Even when I try to explain them as simply as possible.
TP-Link has not enabled MLO for BE900 which is their top-tier full fledged router. They simply don't mention that it supports MLO on it's product page
Compare that to BE800 product page below which explicitly mentions MLO being part of the specs.
Since the Wifi7 specs were finalised few days ago, TP-Link advertising BE900 as Wifi7 router without the crucial MLO support is blatant false advertising. I wrote to TP-Link support regarding this and their reply was, your concern has been forwarded to the firmware team. That's it nothing else. My BE900 doesn't even connect to Apple Wifi6e devices on 6Ghz band. The band is visible for few minutes after router has booted and then just disappears. I thought it was hardware issue but replacement router also has same issue.
Apple specifically wants 2.4Ghz + 5Ghz + 6Ghz bands to be combined as per stated here
But BE900 can't even combine those bands. It can combine just 2..4Ghz and 5Ghz.
So this MLO post has turned into a full blown rant against TP-Link BE900. What's worse, I have 2 of them as they are advertised as EasyMesh compatible and they can't even Mesh 5Ghz and 6Ghz bands separately. They remain orphaned on nodes with no security applied so anyone can just join them. TP-Link support asked me to use the second BE900 as a dumb access point with it's own wireless network. :p
In short, don't buy this bullcrap router until and unless they release MLO firmware, allow https cert upload for ddns, support EasyMesh on all bands and allow 2.5Gbps speed on it's SFP port.
