Apologies for the length of the post once i get going there's no stopping me
The article on Cardbus vs USB sounds ideal as there are a lot of confused people out there including me
Update on my current situation;
DIR-855
I am returning the device for two reasons, the first is that it came with a screen defect and scratches all over the OLED display.
Now the more important reason,
I couldn't get the 2.4GHz wireless to go higher than 3MB\s no matter what i did, i tried everything, and for me it has to be the worst 2.4GHz wireless i have had in ages. I followed the instructions from Dlink to the letter, put the router in N only mode, WPA PSK 2 with AES cipher to achieve 300mbps.
I also received the DWA-643 this morning, and this was nearly also going to go back as i thought that the new adapter was causing my speed issues,so i dug out my old Netgear DG834N and tried that with the new adapter. My wireless speeds shot up to 8MB/s. I had a friend come around with a DIR-655 and that also registered the same speeds as the Netgear.
I usually run my wireless with no encription, hiding the SSID and using a network or mac address filter to couter any WPA encryption speed loss and stop unwanted quests, but that made no difference to the DIR-855 at all. I am totally disappointed with the hardware, maybe mine was faulty but it was just shocking.
So what now,
I have ordered a Belkin N1 Vision, I wanted something with Gigabit LAN and excellent wifi, i know i could have gone for the DIR-655 but i really like the look of the Belkin and the review and wireless performance charts swung it for me.
I want this device to tide me over until some good Expresscard dual band adapters and 2nd generation dual band routers come out, as it would seem that to get good 2.4GHz performance we will have to wait a little longer,which is again disappointing for me as i thought the DIR-855 was that solution. The fact is thought that Dual Band adapters or just not prolific over here yet so i makes sense to wait rather than have a Dual Band router with less than average 2.4GHz performance.
I currently have trouble streaming HD content, i dont think that this will change however when i receive the Belkin tomorrow, i tried my friends DIR-655 with the DWA-655 and that had the same trouble as the 855. Also my Netgear DG834N cant seem to do it either.
Although i get 7-8 MBps i must assume that it is some sort of interference causing my problems, there are up to 6 other routers that my WIFI card picks up at any one time so i can only imagine that they conspire to hamper my 2.4GHz performance.
When i am upstairs which is one floor directly up from the router which is located in the living room, i see 4 green bars on the Dlink utility, I have 95% signal strength, 300Mbps connection and i am currently one channel 1.
When i stream HD content though the bars start to change, going down to 1 in some cases and sometimes going red altogether, when this happens my videos start to stutter for a period and then come back. It is strange as when i am not streaming video the bars stay on 4 all the time.
From what i remember though i did return a D-link PCMCIA N adapter some time ago for the very same type problem, however seen as though i have tried 3 routers and 2 different cards i am not inclined to blame the DWA-643 this time.
What makes me question this a little though is the fact that my built in WIFI which is 802.11g can stream most of my HD videos fine, it cant handle the bigger ones but that is to be expected, where as when i play the same ones with the DWA-643 they still stutter at certain points, even when connected solely at 802.11N. The only reason i can think that this is happening is that the DWA-643 can't sustain enough bandwidth for the videos to play properly maybe due to antenna size, this is why is moves around so much on the signal connection bar when streaming. Even though i have a 95% connection at 300Mbps according to the utility.
I could opt to try a different Expresscard but i dont think this is my problem, i know that Belkin does a N Expresscard but from what i have seen on the Belkin it uses a Atheros chipset so i should have good interpolation between the devices anyway.
So basically i will have to wait for some decent 2.4/5GHz equipment to come out in the UK as the Linksys and Dlink for me so far dont seem to have the 2.4GHz legs.
Any advice on any points i have made about my WIFI connection would be most welcome
