WiFi Vlan on AC3100
I have AC68U running alpha merlin as AP mode with VLANs script, but I got an error of incorrect password when connecting to guest wifi (except guest wifi # 1 on both 2.4 and 5GHz with default VLAN 501 and 502).
If I config guest wifi with open system, no error happen.
I have downgraded some versions of merlin, but the errors was still there.
Any advices from you to solve?
RT-AC68U or RT-AC3100?
Alpha firmware? Did you do a full reset after flashing to that firmware? Then minimally and manually configure it. Without using a saved backup config file?
Hi, sorry but I haven't tried the 386.1 alpha as it is doesn't support my router RT-AC87U and I didn't see a point installing it just on my AP RT-AC68U (now I won't do it for sure if as you say a downgrade with a factory reset doesn't fix it :(), so I don't know how exactly it affects the guest SSIDs mapping to VLANs. I hope it doesn't break this functionality as that would be a problem for a lot of people.
I read on the alpha thread that it introduces some changes as it adds guest WLAN support to aimesh nodes but that's about all I know, maybe someone else who is using the script with the new firmware can help you.
