One my Windows 10 desktop computer, I'm experiencing a problem with accessing USB drive connected to the router by Samba protocol. Here's what happens: I browse directories and files on the drive as expected. But if I open a file from there, Windows is losing connection to the directories, and any further attempt to enter a directory results in error code 0x80070035, "The network path was not found". The directories now appear in Windows with a cross, probably indicating a problem:
Note that one of the directories, "Quicken", does not have the cross - indeed, this one directory never experiences this problem, so I can always enter it when other directories are inaccessible.
After some time, some recovery takes place*, and those directories become accessible again, until I open another file. Sometimes it takes not one but 2-3 openings to cause this. There are no messages from Samba in router log at that time.
My another Windows 10 computer, a laptop, does not experience this problem - on the same drive, I can open as many files as I wish, everything stays available. These two computers have the same build of Windows, the only difference is that the one with the problem is connected to the router by Ethernet, while the 2nd one connects wirelessly.
I tried all combinations of the router support of SMB1 - SMB1+2 - SMB2 only, plus Windows supporting or not SMB1 - no difference at all.
If anybody has an insight into what to look into, it would be greatly appreciated. One one hand, it looks like Windows problem because two computers behave differently; on another, one directory stays totally "exempt" from this problem, so it looks like the router also has some play in it.
*) When I noticed this first, about half a year ago, the recovery was taking couple of minutes. Now, as I can see, it's taking much longer.
