Windows 2008 box as home router?
Also make sure your isp doesn't throttle bt ;)
I'm not sure abotu tomato, but dd-wrt will show u the router cpu usage...so may wana try that and see if your router cpu load is very high with bt.
That's a good idea. I guess I could at least SSH into the router and do "top"...
Hmm. Top reveals that the CPU load is never above 15%... That's interesting. Maybe a faster, dedicated solution doesn't necessarily help.
Torrents/P2P software hits "concurrent connections" of a router hard...and the wrt54 doesn't handle many...even with DD or Tomato.
Home network routers dont have sufficient cpu power or RAM available for handling so many connections. I think they're not even using the real cpu.
I suggest you try with something more pro, but not expensive. An Linksys RV042 can manage 60mbit wan connections. I had 4 pc's with running torrents at full 40mbit line and couldnt crash it.
I don't suggest using pc for router. It can handle large connection, but it's not reliable like routers and not so responsive at large loads.
