Wireguard Wireguard amtm installation?
I just bought mine and I have been trying to figure this out as well. I went modprobing a couple of times and I am not finding it inside my list of modules.
:/tmp/home/root# modprobe -l | grep wg.ko
cannot seem to lsmod it either
/tmp/home/root# lsmod -l | grep wg
if you are indeed on 386.4 or later it should be there.
Try any of:
find / -name wireguard.ko
modprobe --show-depends wireguard
should be located here:
/lib/modules/4.1.52/kernel/net/wireguard/wireguard.ko
load it with:
modprobe wireguard
or
insmod /lib/modules/4.1.52/kernel/net/wireguard/wireguard.ko
check so that it has loaded with:
lsmod -l | grep wireguard
wireguard             108484  0
Wireguard manager loads the built in module for you, so you don't have to bother.
//Zeb
What do the following commands show
which wg
wg --help
Just install wireguard manager in amtm. Have you tried it?
AX56U would require using 386.4 (or later) with buildt in wireguard modules, as there are no custom modules for this model.
Here is a guide to get you started
https://github.com/ZebMcKayhan/WireguardManager/blob/main/README.md#table-of-content
If you run into problems, post it here:
Good luck!
//Zeb
Thank you!
