Solved Wireguard Server, no access to intranet from WAN
Start with the LAN setting. Hopefully the other settings will follow, but you will need to check every thing. If you any static ip addresses setup, you will need to modify those as well.
Likely you will need to reboot some clients after updating your LAN settings.
I changed to 10.x.x.x remotely, updated the DHCP table and clients, and everything is working well. Thanks
