Wireguard Server VPN Configuration - AX11000 Pro
undefined
Hi there.
I recently obtained an Asus RT-AX1000 Pro and have been trying to configure Wireguard in Merlin with my VPN provider (Mullvad).
Coming from an RT-AC88U, I was previously using OVPV, so Wg is new to me.
I downloaded a configuration file from my VPN provider successfully, imported it as a VPN client and then used the VPN director to add all required local devices to my VPN. This works great.
Next, I created a Wg server in Merlin and then, using the android Wg application, I successfully connected my phone, and I now have remote access to my network. This also works great.
Before using Wg as my phone's VPN, I was previously using my VPN provider's native application. Still, I have now had to disable this app since Android only allows a single active VPN. My question is, how do I route my routers Wg server through the VPN that I set up in my Merlin's Wg client settings so that all traffic using my router's Wg server is also passing through Mullvad?
I hope this makes sense; as mentioned previously, I'm not too knowledgeable in regards to Wg and have been learning as I go.
I hugely appreciate any help or advice as its something I have been struggling to configure.
Thank you.
