Wireguard VPN soon?
Stardust
Hey all.
Is Wireguard VPN being supported by Merlin in future firmware?
If yes , is it restricket to new hardware? In that case which routers?
Is it possible to set up now for an old 68U like mine?
Or should I buy a new one?
Regards
John
This has been asked multiple times. If you do a search you'll find what you're looking for.
Hey all.
Regards
John
You will need a newer kernel base > version 3.10.. the only 2 routers have kernels to support wireguard (RT-AC86U and RT-AX88U)
Thanks. So for now it will be wait and see - I will buy minimum an AX next time and only one choose from.... ?? (And no AX clients so far)
