Wireless Log
cdikland
I have been using Merlin FW on all my (supported) routers for as long as I can remember. Today, I decided I would like to experiment with AiMesh and started by flashing the official FW (RT_AC68U_300438445717) on my AC68U AP before tackling my main AC86U router. When I consider some of the lost functionality and the pitiful wireless log I wonder if it is worthwhile. My main beef is how wireless clients are listed in this log displaying only the MAC address.
Is there a tool/utility/etc that one can use to translate this log from MAC to IP addresses or do others just live with this inconvienience???
I've been messing with IT since MS-DOS. My goal has long been to keep it simple... I make choices to keep my boxes as plug and play as possible. So, I live with it but it's not an inconvenience since I don't bother with it.
I'd suggest you keep your eye on the ball before aborting... if you've decided to try AiMesh, then do that and then decide if it's worth it.
OE
