Cooldragonex
Hi guys! I have a RT-AC56U & AC87U all running the latest merlin firmware.
My AC56U is setup as the main router wheras my AC87U is setup as a access point in the second storey of my house.
I used my iPhone 5s to do a speedtest on both my routers (Tested it by standing beside both routers using 5ghz band)
RT-AC56U - Down 110mbps, Up 95mbps
RT-AC87U - Down 30-55mbps, Up 20 - 55mbps
As u can see from the results, i get half of what my main router download and upload speed on my AP. I bridged my AP to the router using LAN port 1 & i get the advertised ISP speeds while on LAN connection on my AP to a PC.
As for both router channels and frequency, i have set it to:
RT-AC56U - 40Mhz Channel 161
RT-AC87U - 40Mhz Channel 153
Same Wireless 5Ghz SSID
Any ideas what is the reason behind the slow & fluctuating wireless speed? Thanks in advance!
