Hi !
Can anyone help me with a small issue I have with my WNDR3700, I use it as an AP, but it constantly shows the wrong date & time (Jan 2000!!).
I've looked through the setup menus and cannot find any manual settings to set the date & time and the user manual only states that the device uses NTP and should the time state Jan 2000 then the device has not yet successfully sync'd with one of its pre-programmed time servers.
Does anyone have any suggestions on how I might get the thing to either sync OR set the time from an LAN based NTP service instead of the preprogrammed ones (whatever they are?)?
Thanks for any help!
Griffo.
Griffo.
