WOL not working
EDIT3: Have i made the static arp correctly ?
ASUSWRT-Merlin RT-AC86U 384.19_0 Fri Aug 14 19:19:51 UTC 2020
classcomputers@RT-AC86U-AAA8:/tmp/home/root# arp -s
arp: need host name
classcomputers@RT-AC86U-AAA8:/tmp/home/root# arp -s 192.168.11.122 D4:5D:64:F0:C
0:F6
? (147.12.206.1) at 48:f8:db:c2:81:24 [ether]  on eth0
? (192.168.11.122) at d4:5d:64:f0:c0:f6 [ether] PERM on br0
yes ! but of course, as such, it will not survive a router reboot ...
i don't intend to turn the router off, but it will undoubtedly get turned off and on for some reason or rebooted, can i make it survive a reboot ?
... besides services-start, I use a cron command because I noticed that sometimes (do not ask me why or because of what), the arp table was reset ....
We've been through all this the last time you asked these questions:
http://www.snbforums.com/threads/help-setting-static-arp.39823/post-332625
Yes we did and it was a struggle then. Think i missed making executable, so i just logged into my router and typed 'arp' and i can see the PERM in the line, i then directly typed ' chmod a+rx /jffs/scripts/* ' so i will test after a reboot, i should then see PERM on that line if i did it right ?
login as: classcomputers
classcomputers@192.168.11.1's password:
? (192.168.11.8) at 08:62:66:50:71:41 [ether]  on br0
? (147.12.206.242) at 98:5f:d3:3c:77:4d [ether]  on eth0
? (192.168.11.84) at 00:59:03:39:2f:19 [ether]  on br0
? (192.168.11.95) at <incomplete>  on br0
classcomputers@RT-AC86U-AAA8:/tmp/home/root# chmod a+rx /jffs/scripts/*
ill keep my fingers crossed that what i have already will work, otherwise ill have to ask lots of questions and upset people.
