World of warcraft latency issues
BloodFX2021
Hi Since upgrading to an ax88u 386.2_4 with vpn and skynet, I am getting constant high latency issues and the game is unplayable or just disconnects me.
Can skynet cause high latency or is it just my vpn?
1 2 ms <1 ms <1 ms RT-AX88U-5ED0 [192.168.50.1]
2 22 ms 21 ms 22 ms 10.8.0.1
3 30 ms 22 ms 22 ms no.rdns.ukservers.com [94.229.72.1]
4 22 ms 23 ms 22 ms no.rdns.ukservers.com [78.157.210.153]
5 23 ms 24 ms 22 ms hu0-1-0-5.rcr21.b023101-0.lon13.atlas.cogentco.com [149.11.160.65]
6 21 ms 23 ms 43 ms telecomitaliasparkle.lon13.atlas.cogentco.com [130.117.14.86]
7 46 ms 45 ms 56 ms 195.22.208.79
8 46 ms 43 ms 89 ms 195.22.192.29
9 158 ms 144 ms 132 ms ae1-br01-eqml2.as57976.net [137.221.82.33]
10 * * * Request timed out.
11 291 ms 242 ms 236 ms et-0-0-29-br02-eqpa4.as57976.net [137.221.65.35]
12 * * * Request timed out.
13 1006 ms 880 ms 665 ms 137.221.65.77
14 146 ms 134 ms 133 ms et-0-0-31-pe01-eqam1.as57976.net [137.221.78.67]
15 133 ms 131 ms 139 ms 185.60.112.157
Trace complete.
Try the trace without the VPN. Also, ping with and without VPN.
VPNs will almost always add latency, due to encryption and also VPN providers not necessarily having routing that's as optimal as a multihomed ISP.
What s the second hop?
That looks like quite a large jump.
#2 would be router to internet provider, pretty normal. #9 is where things go to hell
You are bouncing from UK to Italy to North America, that's not really an optimal route.
Use a VPN with an exit node in North America directly if you're playing on US servers.
