speedingcheetah
Anyone know of a good mini pcie wifi card that I could get to make use of the higher AC wifi speeds....my current card Intel AC7260 only does 866 link speed.
Also, my laptop is only 2 stream (2 antennas). Not sure if 3 antennas are required to support the higher AC standards. I have tried adding in a 3rd antenna to my laptop, but in my tests with my 3 stream N router at that time, it made things worse and more unstable than just the 2 stream. I was told its has to do with the way antennas and radio signals work and antenna continuity or something. Makes sense, the 2 regular antennas are behind the lcd screen, and the 3rd that I added is under the bottom case of the laptop, completely different orientation than the others.
