speedingcheetah
Adding DHCP reservations in the Linksys is the exact same process. Copying and pasting from a text file works as well and takes the exact same amount of time.
The only GUI that is significantly slower is Netgear because you actually have to enter a 2nd screen to input the individual reservations.
Wrong. First, the DCHP reservation screen took alot longer than it should to find where they buried it. Second, The Linksys requires an additional field called Device name, then they split the last 2 decimals of the IP address into 2 separate fields. Then the MAC address field. Then you have to click save. Then OK to save the whole thing....and router reboots to save changes. The Linksys takes much more time to set.
BTW, thanks to this normal behavior of Smart firmware...., I am unable to get the router to keep my settings when I set it up on one network(or not on one at all) then connect it to a live network. It resets all of its LAN/WAN and related DHCP settings every-time.
