I finally received this router that I ordered from Best Buy. I had high hopes for it, based on its review here and the forum comments I've read. Unfortunately, I'm not impressed. Its performance stinks.
I've run several speed tests from speedtest.net and I get ~1.5 Mbps down and ~.5 Mbps up. This is from my pc connected via ethernet cable. If I directly connect my pc to the cable modem, I get between 70-95 Mbps down and 20+ up.
When I connected my Usb 3 disk, first it showed up, then disappeared. I had to unplug, replug and reboot multiple times to get it recognized again. When I played a test video to my Samsung TV via 5Ghz wireless, it stuttered, paused and jerked.
There has to be something wrong somewhere. I've changed multiple settings and rebooted many times to no avail.
The odd thing is that they initially sent me the wrong router, a WRT1200AC which worked much better than the 1900 I ordered.
Does anyone know of the settings I need to make this thing perform as expected?
