x3mRouting x3mRouting failed to configure based on VPN client routing
worf
Hi, guys.
First, I restored to factory default.
Configure vpn in web ui
relaxed: Accept DNS Configuration
Policy Rules (strict) :"Force Internet traffic through tunnel
step:
1、Test VPN without using x3mRouting
The result is that all traffic is a broadband interface
traceroute to www.baidu.com (14.215.177.38), 30 hops max, 38 byte packets
 1  10.0.0.1 (10.0.0.1)  0.301 ms  0.230 ms  0.207 ms
 2  100.64.0.1 (100.64.0.1)  2.409 ms  2.758 ms  2.779 ms
 3  182.150.190.221 (182.150.190.221)  3.606 ms  3.728 ms  3.522 ms
 4  171.208.199.65 (171.208.199.65)  3.760 ms  171.208.199.213 (171.208.199.213)  3.975 ms  61.139.121.41 (61.139.121.41)  3.541 ms
 5  202.97.29.21 (202.97.29.21)  30.634 ms  202.97.96.34 (202.97.96.34)  38.512 ms  202.97.29.17 (202.97.29.17)  30.351 ms
 6  113.96.5.82 (113.96.5.82)  40.200 ms  113.96.5.126 (113.96.5.126)  37.439 ms^C
2、The test uses x3mRouting Policy routing.
run command
x3mRouting ALL 1 TEST aws_region=US
The ip test result used in the applet is still broadband output
52.93.178.143
44.192.0.0/11
52.93.60.0/24
52.93.50.150/31
99.77.151.0/24
54.190.198.32/28
52.93.50.174/31
52.144.194.192/26
54.210.0.0/15
15.230.39.70/31
44.242.161.20/30
52.93.50.164/31
num pkts bytes target prot opt in out source destination
1 0 0 MARK all -- br0 * 0.0.0.0/0 0.0.0.0/0 match-set TEST dst MARK or 0x1000
wolf@RT-AC86U-E308:/tmp/home/root# ip rule
0: from all lookup local
9995: from all fwmark 0x1000/0x1000 lookup ovpnc1
32766: from all lookup main
32767: from all lookup default
What should I do to use it correctly?
Amazon US traffic is not traversing thru the iptables rule.
Please try this...go into the policy routing section of the OpenVPN Screen and add an entry for your router IP address and route to the WAN interface. Then, create a DummyVPN1 entry and route to the WAN.
What website are you accessing to test?
Test 1
Test is to route a website thru the VPN tunnel:
x3mRouting ALL 1 WIP dnsmasq=whatismyipaddress.com
Then, go to the website. It should report the ip address of your VPN.
Test 2
Go to the OpenVPN screen and add an entry to route your laptop to the VPN. Then, go to whatismyip.com. It should report the IP address of the VPN. Next, create a vpn bypass rule for the website.
x3mRouting 1 0 WIMYP dnsmasq=whatismyip.com
You may have to clear broswer cache for this to work or open a tab in a different browser. Then, go to whatismyip.com. It should report your WAN ip address.
Test 1
x3mRouting ALL 1 WIP dnsmasq=whatismyipaddresss.com
Test 2
Thanks Xentrk.
I want to test the first method "Test 1".
I must add two policy routing . One route IP to wan interface,eg. my lan IP 192.168.50.0/24 to wan. and add Dummy ip to vpn . eg. 172.16.0.1 to vpn
Then run the command
"x3mRouting ALL 1 WIP dnsmasq=whatismyipaddresss.com", correct?
Failure. I've never been able to configure it correctly
x3mRouting 1 0 WIP dnsmasq=baidu.com,qq.com,sogou.com
x3mRouting 1 0 WICN dir=/tmp/mnt/vpn/RT-AC86U/vpn
Thanks Xentrk.
Let's take a step back and clarify your requirement. Do you want to route all of your LAN traffic to the VPN and bypass certain sites like Baidu? In the first example, you were not routing any LAN clients to VPN Client 1. But then you were creating a rule to bypass VPN client 1 for Amazon. So that confused me. Then, in a later example, you were creating rules to route certain websites to the VPN.
I wanted you to route the Router IP address 192.168.50.1 to the WAN. Not the entire LAN (e.g. 192.168.50.0/24). Unless that is what you want to do. I just wanted to see an entry in RPDB for VPN Client 1 to help in the troubleshooting.
Examples:
Please do the test 1 and test 2 as I outlined in my post above rather than changing the websites. It will prove if the rules are working correctly.
Test 1
Test 2
You may have to clear browser cache for this to work or open a tab in a different browser. Then, go to whatismyip.com. It should report your WAN ip address.
Hi Xentrk,
A question regarding the routing. How can we configure to route all LAN traffic to WAN and only Netflix ASN to the VPN?
Thanks.
Hi Xentrk,
Thanks.
You need option 3. In the OpenVPN Client Screen, turn on Policy Rules.
In this example, VPN Client 1 is the destination. Source is 'ALL' traffic. This will force all Netflix traffic to the VPN, no matter the LAN device.
ASN Method​
Route all traffic matching IPSET list NETFLIX created from AS2906 to VPN Client1.
x3mRouting ALL 1 NETFLIX asnum=AS2906
This may
dnsmasq Method​
x3mRouting ALL 1 NETFLIX dnsmasq=netflix.com,nflxext.com,nflximg.com,nflximg.net,nflxso.net,nflxvideo.net
This requires that Accept DNS Configuration not be set to Exclusive though. When using Exclusive + Policy Rules, dnsmasq is bypassed.
Thanks for sharing the commands and your prompt reply! I have added both commands using different IPSET name.
However, my LAN traffics are still routed to the WAN instead of VPN Client 1 for Netflix. Here are some of the information that I have captured.
/tmp/home/root# liststats
NETFLIXASN - 180
NETFLIXDNS - 0
/tmp/home/root# iptables -nvL PREROUTING -t mangle --line
Chain PREROUTING (policy ACCEPT 5303 packets, 1420K bytes)
1 0 0 MARK all -- br0 * 0.0.0.0/0 0.0.0.0/0 match-set NETFLIXASN dst MARK or 0x1000
2 0 0 MARK all -- br0 * 0.0.0.0/0 0.0.0.0/0 match-set NETFLIXDNS dst MARK or 0x1000
DNS: Strict
Router Mode: RT-AX86U
NETFLIXASN - 180
NETFLIXDNS - 0
DNS: Strict
Don't see any packets passing thru the rules. What does the "ip rule" command show?
You don't need to use both methods for Netflix. Just use the ASN method for now.
As a test, create a rule for an what is my ip address site to the VPN.
x3mRouting ALL 1 MYIP dnsmasq=whatismyip.com,whatismyip-address.com
Go to one of those websites and verify it displays your VPN IP address.
Next, go to ipchicken.com and see if it reports your WAN IP address.
Noted. I have removed the dnsmasq method.
Both websites showing my VPN IP and ipchicken.com show my WAN IP.
@hprogramming
Good. If it works, don't change it.
If you install option 4 scripts, there is a utility called ASN Lookup. You can type "asn netflix.com" at the SSH prompt and it will display the ASN the domain belongs to. What ASN displays on your end? I am curious if it is one of the other ASNs that belong to NF.
I'm getting the AWS ASN.
- Resolving "netflix.com"... 6 IP addresses found:
54.73.148.110 +PTR ec2-54-73-148-110.eu-west-1.compute.amazonaws.com
+ASN 16509 (AMAZON-02, US)
+ORG Amazon.com, Inc.
+NET 54.73.0.0/16 (AMAZO-ZDUB6)
+ABU abuse@amazonaws.com
+GEO Dublin, Dublin (IE)
18.200.8.190 +PTR ec2-18-200-8-190.eu-west-1.compute.amazonaws.com
+NET 18.200.0.0/16 (AMAZON-DUB)
54.155.246.232 +PTR ec2-54-155-246-232.eu-west-1.compute.amazonaws.com
+NET 54.155.0.0/16 (AMAZON)
2a05:d018:76c:b685:3b38:679d:2640:1ced +PTR -
+NET 2a05:d018:400::/38 ()
+ABU email-abuse@amazon.com
2a05:d018:76c:b683:f711:f0cf:5cc7:b815 +PTR -
2a05:d018:76c:b684:8e48:47c9:84aa:b34d +PTR -
Thanks for the feedback @hprogramming . I'll retest the ASN method on my end again and make any new recommendations if necessary for those that prefer the ASN method. I made a change a few months back and route all AWS traffic thru my VPN, which includes AS16509. So, I wouldn't have been able to detect an issue. Previously, AS2906 was all that was required.
Understood. Thank you!
