Phillips39
Hey,
My current set up is 2x XT12 and 2x XT9 running in AiMesh. Main router is XT12. XT12's run latest @RMerlin firmware, the XT9's on the lates stock firmware as unfortunately no Merlin support. Everything has been rock solid and works well.
My network has been expanding to the point at which I'm now considering running a separate IoT network for my ring devices, locks, Hue bulbs and the like. I'm aware this cannot be done via the current Merlin build as it is on 3004, so am looking at the possibility of flashing the XT12's to the latest stock 3006 firmware.
Off the back of that I realise that I may get compatibility issues with the Mesh with the XT12s being on 3006 and the XT9s being on 3004. As such, I am looking into replacing the XT9s with either their business counter part the EBM68 (as these run 3006) or 2 more XT12s. Even though the EBM68s would be more aesthetically pleasing replacing the currently wall mounted XT9s, I'm leaning towards the XT12. Rationale being that the XT12s are more powerful (and my current 2 I have been really pleased with), and also because if I find it all goes south on 3006, I can flash them all back to Merlin. Plus, hopefully, Merlin may release a version of 3006 before long which I could then apply to all 4 XT12.
I have also considered upgrading to Wi-Fi 7 as main router and putting the XT12s into secondary nodes. However, from researching, Wi-Fi 7 routers still seem to be problematic. Plus only a handful have Merlin support of which the majority are the ROG style which won't go down well at home!
Would appreciate any input and advice here. TIA.
