YazFi GUI Tab not showing up under Guest Networks Page
Astronautspiff
I have searched these forums but have not been able to find an answer to my issue. I am running YazFi on Asuswrt-Merlin firmware 386.10 on a GT-AC2900. I have installed YazFi v4.4.4 and when it installs it says:
Welcome to YazFi v4.4.4, a script by JackYaz
Checking your router meets the requirements for YazFi
New version of YazFi_www.asp downloaded
Mounting WebUI tab for YazFi
Mounted YazFi WebUI page as user1.asp
You can access YazFi's configuration via the Guest Networks section of the WebUI
Alternatively, use YazFi's menu via amtm (if installed), with /jffs/scripts/YazFi or simply YazFi
When I navigate to the Web GUI for the router I see this:
Obviously there is no tab for YazFi. When I run "/jffs/scripts/YazFi startup" I get:
but still no YazFi tab in the Guest Network page. When I run YazFi I get:
## __ __ ______ _ ##
## \ \ / / | ____|(_) ##
## \ \_/ /__ _ ____| |__ _ ##
## \ // _ ||_ /| __| | | ##
## | || (_| | / / | | | | ##
## |_| \__,_|/___||_| |_| ##
## v4.4.4 ##
## https://github.com/jackyaz/YazFi/ ##
sed: /tmp/menuTree.js: No such file or directory
WebUI for YazFi is available at:
WebUI page not found
1. Apply YazFi settings
2. Show connected clients using YazFi
3. Edit YazFi config
4. Edit Guest Network config (SSID + passphrase)
5. Show QR Code for Guest Network
u. Check for updates
uf. Update YazFi with latest version (force update)
d. Generate YazFi diagnostics
e. Exit YazFi
z. Uninstall YazFi
Choose an option:
I am assuming this is part of my problem but I don't know how to fix it:
Are there any logs that I can pull to possible narrow down the issue here?
I saw someone have the WebUI page not found message here yazfi-settings-not-persisting-across-reboot but I could not understand the proposed solution.
Sorry if this is a simple fix, I am new to this and trying to learn.
There is no support for the illegal Vortex firmware. And removing the top part of your original image won't change that.
Okay, in my defense, I was not aware that this was the case until I did a little googleing on the subject. This was given to me with this already flashed so I did not know. Additionally, I have a GT-AC2900 that is giving me the same issue so I am now aware the Vortex one should be trashed and I am currently trying to get support for my ASUS branded router as it has the same issue.
