Yet another malware block script using ipset (v4 and v6)
am I missing something or not set up right? this is what I get when I run ya-malware-block.sh -Loaded sets YAMalwareBlock1IP (3142), YAMalwareBlock2IP (1) and YAMalwareBlockCIDR (1) in 3 seconds
does it create files somewhere ? as I see none and how can I tell if it is actually blocking things?
thanks
Can you do:
rm /jffs/ipset_lists/ya-malware-block.url_list
wget --no-check-certificate -O /jffs/scripts/ya-malware-block.sh https://raw.githubusercontent.com/shounak-de/misc-scripts/master/ya-malware-block.sh
Also, can you do this as a test:
wget --no-check-certificate -q -O- "https://raw.githubusercontent.com/firehol/blocklist-ipsets/master/firehol_level3.netset" | wc -l
and see if you get a number like 38433 or something big
It does create a /tmp file, but it gets deleted before the script exists. You'd be able to see the blocked packets with:
iptables -vL -t raw
In this moment My internet is giving me issues but the new script took
YAMalwareBlock1IP (65535), YAMalwareBlock2IP (41787) and YAMalwareBlockCIDR (5154) in 1646 seconds
a very long time
It should not take that long there is nothing in the new script that is different other than the iptables rules. Is your router busy at the time you ran it.. checking cpu load may help
Well looks like something is wrong with the new script for me, dont know what, the previous script ran in 30 to 40 seconds this one has 4 minutes and counting
this is the top command a few seconds ago
Mem: 103616K used, 136056K free, 0K shrd, 8296K buff, 36096K cached
CPU:  0.5% usr  2.5% sys  0.7% nic 93.6% idle  0.0% io  0.0% irq  2.3% sirq
And in this time, already 5 minutes the router CPU does not go pass 5%
EDIT: Im testing deleting the quiet option on the wget so I can see how much its taking to download the files, I think there is my issue... Ill keep you posted
If you have this script in the services-start, can you try a reboot? I think it is blocked by another process somewhere. The timing should show up in the syslog
Its the download times its extremely slow , Im having issues with my ISP they are downloading at B/s it stuck downloading the raw.githubusercontent.com/firehol/blocklist-ipsets/master/cybercrime.ipset
It says the eta 3m 52s and its just stuck there without doing anything, I rebooted the router and tried again, because the other script was so fast...
I also run adblocker and I had to kill it to get :
38427
I did the rm and the wget and restarted adblocker and got this on when the adblocker was also running:
i
0
and on the test to check I get the following:
Chain PREROUTING (policy ACCEPT 4631K packets, 4431M bytes)
pkts bytes target prot opt in out source destination
Chain OUTPUT (policy ACCEPT 134K packets, 69M bytes)
which I guess may take a while to get a hit.
Is adblocker not compatible as it sends it to pixelserv when that is running when I do the wget?
thanks
Can you do:
Updated by deleting .sh and .url_list,
ran the wget, left the cru as is, restarted the script, works like a charm. Excellent results in the log as well.
Those who are stuck on wget, can you do these:
nslookup raw.githubusercontent.com
ping raw.githubusercontent.com
For me there are no issues with the updated script:
May 12 15:29:29 Firewall: /jffs/scripts/ya-malware-block.sh: Adding malware-block rules to firewall...
May 12 15:30:01 Firewall: /jffs/scripts/ya-malware-block.sh: Loaded sets YAMalwareBlock1IP (65535), YAMalwareBlock2IP (41547) and YAMalwareBlockCIDR (5147) in 32 seconds
@shooter40sw and @jack901 can you do the
and send me the output?
It does respond, but it just stays stuck there "downloading" at 205 B/s with an eta 10m
Server:    127.0.0.1
Address 1: 127.0.0.1 localhost.localdomain
Address 1: 151.101.0.133
Address 2: 151.101.64.133
Address 3: 151.101.128.133
Address 4: 151.101.192.133
:/tmp/home/root# ping raw.githubusercontent.com
PING raw.githubusercontent.com (151.101.0.133): 56 data bytes
64 bytes from 151.101.0.133: seq=2 ttl=57 time=111.679 ms
64 bytes from 151.101.0.133: seq=3 ttl=57 time=111.671 ms
64 bytes from 151.101.0.133: seq=5 ttl=57 time=113.192 ms
64 bytes from 151.101.0.133: seq=8 ttl=57 time=172.787 ms
Reusing existing connection to raw.githubusercontent.com:443.
HTTP request sent, awaiting response... 200 OK
Length: 565615 (552K) [text/plain]
Saving to: 'STDOUT'
-                                                75%[=============================================================================>                         ] 418.38K   205 B/s   eta 10m 19s
My pings are a lot faster:
PING raw.githubusercontent.com (151.101.64.133): 56 data bytes
64 bytes from 151.101.64.133: seq=0 ttl=59 time=26.782 ms
64 bytes from 151.101.64.133: seq=1 ttl=59 time=22.697 ms
64 bytes from 151.101.64.133: seq=2 ttl=59 time=22.424 ms
64 bytes from 151.101.64.133: seq=3 ttl=59 time=21.956 ms
maybe a temporary network issue in your ISP?
Yes my ISP at this moment is very slow.... I reported the issue a while ago but its kind of worse .. I hit enter on the offending github list,.... it started again and now its stuck in the github ssh list, so it has nothing to do with your script, it must be issues on My end, thanks for the hard work to make these scripts work fast and effective!
the ab-solution (sorry for the incorrect name) from john I believe down a few posts. I went to add it to the whitelist and it said it was not blocked.
so I uninstalled and deleted everything and in the process of reinstalling.
will see how this goes.
thanks for the help
Which adblocking solution are you using?
You should be able to whitelist raw.githubusercontent.com.
ok reinstalled first yours then ab-solution and it seems to work as I can now ping raw.githubusercontent.com and it goes thru.
so something got messed somewhere and now seems working.
thanks
